Does anyone still have or know where to find the E36 power window switch retrofit write-up? It was online somewhere, but I can't find it.
Anyone have the E30 to E36 power window switch write-up?
i've looked everywhere and i can't find it either man, sorry i couldn't help. -
Originally posted by kencopperwheatI tried to do it once, but I couldn't get the e30 switch apart. Those clip things on the bottom are a bitch and a half.
It took my forever to finally get mine apart just so I could clean the damn metal contacts... :roll:- Sean HayesComment
You actually got it apart!?Originally posted by SeanOriginally posted by kencopperwheatI tried to do it once, but I couldn't get the e30 switch apart. Those clip things on the bottom are a bitch and a half.
It took my forever to finally get mine apart just so I could clean the damn metal contacts... :roll:Originally posted by Grueliusand i do not know what bugg brakes are.Comment
After an hour or so of playing with various tools, I did get them apart and got the contacts cleaned. I followed the wlak thru on http://bmwe30.net/Originally posted by kencopperwheatYou actually got it apart!?Originally posted by SeanOriginally posted by kencopperwheatI tried to do it once, but I couldn't get the e30 switch apart. Those clip things on the bottom are a bitch and a half.
I had a switch that had to be pressed down ALL the way to work - fixed it. Just keep working with them though, they come apart eventually.
BMWE30 - http://www.bmwe30.net/cgi-bin/datacg...050&Section=02- Sean HayesComment
Yeah, all you really need to do is get in there, open them up, and rub them clean. Some contact cleaner would be ideal, but I just sprayed a bunch of WD-40 in there. It seems to be holding up GREAT.Originally posted by kencopperwheatYeah, I've gotta push mine down pretty damn hard. I'll give it another go tomorrow; but I'll practice first on some non-illuminated spares I have.
Good luck! If you need any pointers, don't hesitate to ask.- Sean HayesComment
No, you put the entire E36 switch in the console in place of E30 one.Originally posted by kencopperwheatYou've gotta get 'em apart if you're going to upgrade, don't ya? :DOriginally posted by Eurospeed88Could you guys take it to another thread? Thanks. :DComment
but most of the time people do this swap they dont cut the harness, isntead they make an adapter out of the old window switch, which requires taking them apart
;) I've done it before on my old eta, its not hard, lemme see if I still have pictures showing which wires match upsigpicComment
This must've been the one that I read.Originally posted by Nate325icbut most of the time people do this swap they dont cut the harness, isntead they make an adapter out of the old window switch, which requires taking them apart
;) I've done it before on my old eta, its not hard, lemme see if I still have pictures showing which wires match upOriginally posted by Grueliusand i do not know what bugg brakes are.Comment
