idling nightmare
  • BimmerBall
    • Oct 2006
    • 185
    idling nightmare
    got a fast, surging idle. checked FPR it seemed good. checked ICV. it seemed to check out ok. what else? i'm out of ideas...
  • Jand3rson
    • 37587
    Does it go up and down, over and over again? Sounds like it probably is your ICV. When mine died on my last E30, my idle bounced up and down from 500 to 1000, back and forth. I replaced it the next day, and it was fine.
    • Kilomph
      • Oct 2004
      • 599
      Same problem
      Mine'll bounce from 300rpm to 1k+ and back, sometimes it'll just die. I've replaced within the past 10k miles FPR, ICV, fuel filter, coolant temp/level, and swapped AFM. I can hear the TPS click when i apply throttle. Sprayed carb cleaner everywhere checking for a vacuum leak, nothin. Any ideas? Sorry for the jack :)
      • BimmerBall
        • Oct 2006
        • 185
        yeah, that's exactly what it's doing. god help you if you cut on the a/c. jesus christ. bad ICV - how can you tell for sure? i just turned teh switch to "on" and felt it vibrate/hum. thanks!
        ok..forgot i added a bottle of fuel injector cleaner last week and ran it a bit. now it seems like it idles fairly smoothly and not as high ~1000 rpm with small fluctuations-barely noticeable. if you cut on the a/c it jumps to 16-1700 - WTF?
        • porsche gt1
          • 237
          did you check your valve cover for a vaccum leak? not just the hose but the whole cover.
            • 34844
            it can get stuck too, and sometimes it will work intermittently. my IVC started dying last year, every once in a while the car would die immediately after starting. sometimes it would hum, othertimes it would be dead and I'd have to wack it a couple times to get it working again.
            • PeaveyBassist
              • Sep 2004
              • 3511
              Just happened on my car... check the plug on the bottom of the injector harness. If that gets corroded, idle will go crazy.
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • BimmerBall
                • Oct 2006
                • 185
                don't seem to be any leaks....my fuel pump is buzzing pretty loudly too.
                • Juanka
                  • Mar 2006
                  • 74
                  mine do the same but it happens when i turned the a/c and the lights on
                  BMW 325IS 1987
                  www.eurocrewpr.com
                  • lordofthewaters
                    • Oct 2005
                    • 714
                    They say that's a sign the pumps on it's way out. But mine has done it since it was a week old )bought brand new). It sounds like a rc airplane.
                    Sarcasm is a body's natural defense against stupid.
                    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                    Old age and treachery will always overcome youth and skill.
                    • nefarious7907
                      • Jan 2005
                      • 1170
                      You never said if it was an M20 but I assume it is since you said yours has an ICV. Easy way to check that the ICV is working is too unplug it. Same with the o2 sensor.
                      http://www.cardomain.com/ride/657387
                      • skool
                        • 31
                        hey guys, I'm new here and I'm having the same problem.
                        My RPM needle will keep bouncing around from 500 to 1250 and so on.
                        I had this problem for a while now, but about 2 months ago I changed a couple fuses and the problem went away.
                        But for the past week, my car had been in the shop and they changed a number of things on my car. I got it back yesterday night and noticed my RPM needle began bouncing all over the place again =/
                        Any ideas from what might have caused this problem to surface again?
                        Any and all suggestions will be helpful!
                        Thanks in advance!
                        • BimmerBall
                          • Oct 2006
                          • 185
                          yes, thread resurrection FTW!
                          update: i've been driving the snot out of it these past few weeks in a quasi Ferrari tune-up style and the idle doesn't surge anymore, the idle speed is just high. bad TPS?
                          • euroshark
                            • Apr 2006
                            • 3491
