3.73 LSD in Eta.
  • Super Eta
    • 1884
    3.73 LSD in Eta.
    This has been discussed but i would like to here what some new and old members have to say about it.
    I might end up putting a 3.73 LSD into my eta "if" that sound i am hearing is infact the 2.93 going out.
    Talked to my local mechanic and he said i might have a flat spot on one of the bearins as whenever im going about 5-10 mph i hear it loud and gets really loud when i take a turn its kinda like a whining and roaring sound coming from the left rear of the car.
    What are the pro's and con's of this swap?
    Ryan
  • bwanac
    • 3354
    I have it.
    PROS:
    -BUZZ BOMB!
    -obviously better acceleration!
    -limited slip baby!
    CONS:
    -highways are no fun. cruising at 80 is about 3k IIRC
    -first gear, basically useless
    Just the obvious ones. In my opinion I would stick with the 2.93 or 3.25 if you can find it. I am going back to the 2.93 LSD iI picked up and am rebuilding. Then selling the 3.73 LSD.
    Just my sporadic thoughts! ;)
    • RedBaron86325
      • 386
      The 3.73 in an eta is a little too extreme. I've been running a 3.73 for about 4 years in my eta. As said above, 1st gear is pretty much useless. You do turn a lot of revs on the freeway, but you eventually get used to it. Here is a pic of my eta with the 3.73 freeway rpms:
      Don't forget the good things Hitler did.
      • Jonathan M3
        • 1837
        3.46 lsd is my suggestion, its about as short as you'd want to go without making the car annoying on the freeways. I had one in mine and loved it, best mod I did for the car. :up:
        BTW, it sounds like your describing a wheel bearing problem not a diff. bearing. If it gets louder or quieter when you transfer the weight of the car in one direction or the other, then its most likely a wheel bearing.
        '05 E46 M3 Imolarot/Cinnamon - CURRENT
        '98 E36 M3 Estorilblau/Dove - SOLD
        '90 E30 M3 Brilliantrot/Black - SOLD
        SRS BSNS Motorsports - 24hrs of LeMons Racer
        • slammed_e30
          • 514
          If you dont drive a lot on the freeway do it, in the city and the twisties you will love it. Just depends on how fast you drive (100+) and if high rpms on the freeway annoy you. Just drive around for awhile without using 5th.
          Originally Posted by Rob
          fucking hell, your car is cleaner in the damn snow than mine ever has been in perfect weather. sedans own me.
          • Bill 84 318i
            • 1600
            Does 3k rpm on the highway really feel that buzzy? I mean that's what 'i's turn...I can't imagine an eta feeling that different.
            • Super Eta
              • 1884
              Daily Driver. So yea ill be on the freeway alot.
              • Deutschmarque
                • Jan 2004
                • 37
                3.25 for mild, 3.46 is the most I would go. I have a 3.25 in my eta track car, good on acceleration, but not a buzzbomb on long straights.
                -Nick
                • James Crivellone
                  Head Janitor
                  • 6304
                  Fun as hell on mine, cept i've got an automatic.
                  Freeway driving is not that loud at all, and city driving is a blast
                  • Super Eta
                    • 1884
                    Goes up hills like its a cake.
                    Thats very true since i have ridden in your car and it wasnt that loud.
                    I think what i will do is replace the two rear bearings since i have two brand new ones (thanks Nate!) then go from there, for this i will goto a local mechanic as i dont want to deal with it right now.
                    • reelizmpro
                      • 9531
                      Their definition of buzzy is probably not the same as yours =]. ETA owners aren't used to a lot of RPM's and visually the "short" ETA tach makes it seem like the engine is buzzy compared to what they're used to. To me, none of the 325's are really buzzy after driving a 318 or M3.
                      88 M3 - LACHSSILBER
                      89 M3 - ALPINEWEISS II
                      • bwanac
                        • 3354
                        It does not feel buzzy, just odd driving constantly at such "high" RPM!
                          • 37829
                          Well, it sounds like I made a good choice on getting my 3.25 LSD!
                          For those of you with the 3.73 in your ETA, what is your top speed?
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • randomtask37
                            • 3154
                            im guessing like 110-115
                            98 M3/4/5
                            • RedBaron86325
                              • 386
                              According to my speedo (don't know exactly how accurate that is), 124mph at 5450rpm (just shy of the 5mpg mark).
