Each time you have a new problem on your E30, post here.
  • ecuaE30
    • Jan 2007
    • 136
    #46
    Need, to fix some small electrical problems. Light wont turn on when the doors open, and the coolant sensor is out, Also my fuel gage doesn't work.
    • rwh11385
      lance_entities
      • 18403
      #47
      thunking when i got over bumps on the road and sloppy steering.
      wheel will move up and down when it is jacked up.
      • Jean
        • 18228
        #48
        Something is up with the fuel level sender it seems....grrr
        • schmidty
          • 1253
          #49
          battery keeps dying overnight
          replace rear side marker cause someone hit me
          headlight adjuster screws for euro ellipsoids
          valve adjustment
          new/reupholster driver seat
          hook/lights horn up to keyless entry
          • mikeedler
            • 6707
            #50
            not surprisingly, I now blew a hole in the coolant hose that attaches to the rear of the head-heatercore.
            I love this thing!
            • brandondan1
              • 1091
              #51
              idle was lopey (700-800), so i 'cleaned' out the ICV. Now it idles at 1500-2000
              91 318is
              • Super Sedan
                • Feb 2006
                • 551
                #52
                Driver's side interior door handle broke at the bottom hinge, door will no longer open from inside. Car no longer locks.
                • turbo_negro69
                  • Dec 2006
                  • 468
                  #53
                  my seat is cocked and if i try to adjust it, when i accelerate the seat goes crunch crack:(
                  new whining noise from engine........time for a swap!
                  synchros in tranny starting to crap out. wonder if i can buy a re-build kit from transtar?
                  91-318i SOLD : (
                  91-318IS for sale
                  95-740i DD
                  84-Monte carlo SS Under construction
                  90-T-bird Supercoupe DD
                  • NC325iC
                    • Mar 2004
                    • 6565
                    #54
                    pass door lock is frozen on lock
                    engine idle is odd (high when cold normal when warm)
                    odd noise when i apply more torque (hoping its clutch/tranny related)
                    marbley tranny
                    fucking paint chips
                    loud valves / possible stripped head stud recepticle (where can i find the correct heli-coil)
                    squeeky ps pump (anyone know why?)
                    brake check light comes on rather randomly (changing switch soon)
                    muffler tips preventing me from putting my RD rear apron back on
                    thats all i can think of
                    • Mastrcruse
                      • Sep 2005
                      • 5340
                      #55
                      My seats SUCK! Everything about them
                      • craig4ie
                        • Sep 2006
                        • 359
                        #56
                        something with the heater
                        no heat at idle, heat with increased rpm, antifreeze smell when heater is on, slight antifreeze drip coming down bellhousing
                        i think a leak around the heater core has allowed air into the system
                        oh and i just replaced the clutch master and slave cylinder
                        1991 Diamantschwarz 318is
                        1998 Cosmosschwarz M3 Sedan
                        • Erick
                          Official R3V Drifter
                          • 11169
                          #57
                          I put a hole the size of a quarter on my downpipe tonight W00T!
                          ..::Support FullOpp::..
                          FullOpp Stickers for sale!
                          Feedback Thread
                          • straight6pwr
                            • Sep 2004
                            • 3450
                            #58
                            double locking my doors doesnt do anything anymore.
                            • JJe30
                              • 2044
                              #59
                              My guibo is all shredded up
                              • blazing
                                • 274
                                #60
                                Besides running and idleling weird
                                Leak from a seam on firewall causing small inner rocker rot
                                Leak from antenna grommet causing rear quarter rot
                                Leaks all possible fluids except rear diff and it is thinking about leaking I'm sure
                                Rear shock mounts = shit
                                Throwout bearing for clutch is making ungodly noises
                                Some issue with the main relay might be the socket
                                Oiling problem in the cyl head
                                Piston slap when cold
                                Shifter linkage bushings are teh fucked
                                Exhaust leak where front pipes meat back pipes
                                Driver side reverse light portion of lens has enough water in it to house guppies
                                Drivers door lock cyl stuck no central locking
                                Windsheild scratched to shit from some tool running wipers with a missing blade
                                OBC lights out
                                Many small dents even one on the fucking sunroof and two outie dents on the trunk lid from some aformentioned tool closing something too big in the trunk
                                Front airdam cracked like the liberty bell
                                Check panel falling out because the trim panel that holds it up is jacked
                                Lower ball joint on driverside shot
                                Thats all for now I'm heading to the garage with a rag and a lighter.:curse:
