i was messing around in the snow and i was going sideways into a corner going about 20mph and hit the right rear wheel into the curb at approximately 10-15mph. it bent up the rim a lil bit, not real bad, but bad enough that im gonna get a new bottle cap for it. what my concern is do you think i hit hard enough that i need get a alignment or even worse bent something, like the trailing arm?
do i need an alignment?
If you need an alignment, you bent something. That's what alignments fix. The problem is, on e30's the only adjusteable spec is front toe in/out.
You could get your alignment checked, and if it is out of spec on anything besides front toe, you'd need to start replacing parts.
Factory wheels are pretty strong. I twisted a control arm and tie rod badly by smashing my front wheel on a curb a few weeks after I got my license. The bottlecap barely had any damage, and I still use it to this day with the same tire. so if you messed one up pretty bad, you likely wrecked other things as well. -
the bottlecaps are soft as shit! i did a 180 into a curb and the wheel tore apart. it looked like something chewed off 1/3 of the wheel.Claus Luthe is my hero.
I hope it is not too serious to hurt anything. Let us know what you find out.
My mom slid into a curb at 20ish MPH and hit the front pass. side wheel. She drives a 99 accord. She needed a new control arm and the frame was tweaked a little:o She got the frame back to normal and the car rides strait now. I hope this is not the same for you.
Good luck.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
well, the wheel isnt THAT messed up, but bad enough that i would go buy another one just to stay on the safe side. about 3 inches of the outter lip is bent/smashed in about 1/4 inch, and because of that the tire bead seats kind of crooked. i driven the car and it doesnt feel out of alignment, but since its the back its really hard to tell.Comment
