Sedan Fuel Tank Capacity?
  • doctorsmoothluv
    • Jun 2006
    • 1088
    I know that there is not much in the way of divergence between two and four door E30's, but does there happen to be a difference with respect to fuel tank capacities between them? I did read the thread in the FAQ concerning Fuel Tank differences, which elaborated on the difference between pre and post 87 model year cars. My car is a 1990 325i sedan, now on fill up, it only accepts somewhere in the neighborhood of 12.5 gallons. Shouldn't my tank capacity be closer to 16 gallons?
  • SchnellerVert
    • Sep 2005
    • 3948
    Is the tank dented? Yes you should have a 63L or 16.3 gallons
    • lordofthewaters
      • Oct 2005
      • 714
      16.6 gallons actually, but yes if it's only taking 12 gallons, something's up. Wasn't a drug car or something? Check for dents definately.
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • NC325iC
        • Mar 2004
        • 6565
        its probly because your tank isnt as empty as you think it is
        • doctorsmoothluv
          • Jun 2006
          • 1088
          Could not attest for the dents or the drugs, I just picked this car up in October of 06. Even though the car was qualified as not being in an accident by carfax I already know differently, there is a little bit of bondo in the rear which would indicate a rear collision. I would assume that either the dent presumption is true or an incorrect fuel tank was installed in replacement. Trust me, I know that that the current tank only holds 12+ gallons and that the fuel gauge is reading accurately (I ran out of gas a few weeks ago). I just wanted to confirm that my tank capacity should be 16 gallons for a sedan. Thanks.
          • Schneider325
            • May 2004
            • 3818
            My 4door ETA only holds 12 gallons..weird
            I'm averaging 130-150 miles per tank now... it used to be 250-300 a few months ago
            there is a dent in the tank I think, but that can't account for 4 gallons can it??
            • doctorsmoothluv
              • Jun 2006
              • 1088
              ^also curious about that as well. Wondering to what extent a dent would affect tank capacity. Hard to imagine a dent contributing to an absence of 4 gallons of tank presence.
              • mrsleeve
                • Mar 2005
                • 16387
                it it was in a wreck the wrong tank may have been replace with the wrong tank. Although I dont know if they are interchangeable
                Originally posted by Fusion
                William Pitt-
                • lordofthewaters
                  • Oct 2005
                  • 714
                  Still the older tanks were 14.3 gallons. Still two gallons missing somewhere......
                  • JGood
                    • Jan 2004
                    • 7959
                    Just to clear up facts, since people seem to be questioning facts:
                    e30's produced up to and including 09/1987 (and ALL M3's) use a 55 liter tank. e30's produced after 9/1987 use a 63 liter tank. There are no exceptions based on 2 or 4 door, etc.
                    15 Liters = 14.52 Gallons
                    16.3 Liters = 16.632 Gallons
                    Now, if you emptied your tank, and filled it up with 12.5 gallons, there is something wrong with physics. The tank holds 16.632 gallons. 12.5 will not fill it when it is empty.
                    A few things to check:
                    Maybe it was not empty because your pump was not in a position to get all of the fuel out.
                    Pipe connecting the 2 sides is clogged.
                    Faulty pump.
                    Something inside the tank taking up volume.
                    Maybe you did not have it filled as much you thought you did (faulty gas station reading, car not level, etc...).
                    Your tank is dented. Bad.
                    Or, as the only other possibility, you have a tank from another BMW, an after market (incorrectly sized) tank, or one from another car all together, in your car.
                    You will not be able to know until you drain the tank from both the crossover pipe and the drain plug, check for objects in the tank, and refill on level surface using a known accurate source.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • doctorsmoothluv
                      • Jun 2006
                      • 1088
                      ^That pretty much answers everything and more. Thank you sir.
                      • iCleaks
                        • Sep 2006
                        • 42
                        If you press the "1000" and "1" on the obc at the same time the obc will display the amount of fuel remaining in the tank in liters. 12.5 gallons is about 47 liters.
                        • doctorsmoothluv
                          • Jun 2006
                          • 1088
                          My situation does not include a 13 button OBC, so I guess I will not be able to utilize that trick.
                          A follow up question to JGood's post: If there were an issue with either the fuel pump or a clog in any of the lines wouldn't there be a noticeable change in engine performance and or efficiency?
                            • 34844
                            don't forget that approxmately 2 gallons of your tank is for the "reserve", the "normal" fill up of the 63 liter tank is about 14.5 gallons.
                            supposedly to fill up the reserve you have to top off the tank several times, but I'm not really sure on that part. I normally just fill it until the pump shuts off by itself, to 14.5 gallons (I always run my cars to the light) and leave it at that.
                            • doctorsmoothluv
                              • Jun 2006
                              • 1088
                              Also did not know that. Mental note made. Thanks Nando.
