sunroof question
  • rede30
    • 4697
    sunroof question
    My old crank sunroof did not click to inform me when my sunroof is closed. today i put in an electric sunroof, thinking this little problem would go away. It did not. The sunroof goes from open to popped without stopping, its a pain in the ass because i dont know when it is closed all the way.
    • 34844
    that is wierd. it should stop... did you reuse your old track, or swap in an entirely new sunroof assembly?
    • rede30
      • 4697
      i didnt change the AL stip, i didnt see a reason to, shit, is this where i went wrong? I figuered it was something else since it was doing this before. Also my sunroof stops trying to crank when its open but it never stops cranking when its popped. Where do you guys tap in for power?
      • rede30
        • 4697
        bump, i have time to mess around today.
        • rede30
          • 4697
          for whoever wants to know, i figured it out. The gear that stops the sunroof when it is open,popped and closed, was out of wack so it was stopping in weird places, I should have figured that out sooner and it was a pain to get it timed right. I never touched the rails so i dont see why these would need to be changed, i only say this because i read a few threads and people said they changed them.
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            the motor should stop all by itself from the gears that turn. there a little relay that automatically turns it off on each setting.
            • hendrixvodu
              • Jan 2007
              • 2514
              how did u do this....because i had to change me slides...and the click is in the middle of the roof...say 8 inches from where it should be ha ha!...ive been going crazy ....can u show me how and where to do this....pref some pix....i have a manual crank roof..... much appreciated !!!!
              -His-
              87 e30 325i
              87 e24 m6
              05 e83 x3
              94 e32 740i 5spd
              -Hers-
              89 e30 325i
              18 f48 x1
              • netcsk
                • Apr 2004
                • 1609
                You have to get the roof in the correct position for the stopping point (fully closed); then pull the gear assembly and crank it to the correct position for the stop on the closed position; then put it back together.
                • hendrixvodu
                  • Jan 2007
                  • 2514
                  so the gears that the actual lever connects to...ic ic....much thanks!
                  -His-
                  87 e30 325i
                  87 e24 m6
                  05 e83 x3
                  94 e32 740i 5spd
                  -Hers-
                  89 e30 325i
                  18 f48 x1
                  • rede30
                    • 4697
                    what i did is i popped the the sunroof and hooked up the motor to a battery i had sitting around, and ran the motor till it would click, and stop. I just played a guessing game and tried different clicks and then i would mount the motor and see if i got it. It took me a few tries but i figured it out with some thinking and logic. I really cant figure out why i didnt have to change the tracks and some people do.
                    • rede30
                      • 4697
                      yea the main gears spin a bigger white gear, you will see when you have the motor in your hand. You will also see why it clicks off and with this you can figure out how to get the timing.
