Whenever I have the Fan on as well as the A/C, it will run for a few minutes or more, and then suddenly fuse 20 will break. It's happened twice in the last two days that I've been using the A/C. It does not occur while moving the shifter into reverse.
Any info would be very helpful.
I'm thinking it's a loose or bare wire that's causing the fuse to pop. Any ideas as to where to look for a loose wire?
