Electric Fan for e30?
  • bimmer8604
    • 3017
    Well, the temperature is rising, and my A/C is functional again, so its time to look for a new electric fan. I removed the mechanical fan back in December, and rather than put another one on I am going to put an electric one in place.
    Wondering what you guys are using. I still have my aux fan in front of the condenser, so I need a main 'puller' fan for the radiator. I don't mind installing a switch, but a thermostat controlled fan would work as well. My price budget is 75-100 bucks.
    TIA
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • MikeE30325i
    • 2356
    i is actually looking for something similiar. let me know if you find something good.
    • bimmer8604
      • 3017
      why dont u just have ur muscle boy just wave a big leaf infront of your engine?
      jk, ill let ya know
      DILLIGAF
      • backtrail69
        • Jul 2005
        • 4471
        Buy a e36 m42 fan switch and a new fan clutch...
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • Mr Deagle
          • 1121
          just jump the aux fan to high, your car doesn't need anymore fans
          • MikeE30325i
            • 2356
            after being on the freeway i hit traffic and it hit the 3/4 temp line. then i had to shut it down and sit on the side of the freeway for twenty minutes.
            you better show me how to step it up.
            • bimmer8604
              • 3017
              the aux fan was fine for me w/o the added strain of the a/c. but i,too, have been stuck in traffic in the lincoln tunnel and had the car start to overheat. it was funny cause there was a new rx8 that was steaming under the hood but luckily traffic picked up and i was able to bring it down a bit.
              and as far as putting an m42 switch in has nothing to do with me finding an electric fan for my car....
              kyle
              DILLIGAF
              • MikeE30325i
                • 2356
                kyle
                yeah, i blasted the heater, and when i started it back up it was at an acceptable level. and with the heater on (around 100 degrees outside, luckily i was going to a waterpark) the heat stayed at an appropriate level.
                • E30 Reaktionär
                  Site Manager
                  • 14451
                  What CFM does anyone suggest if one was to run an electric fan.
                  1992 BMW 325iC
                  1978 Chevrolet Monte Carlo
                    • 34844
                    you already have an electric fan. use the M42 switch and make it so it only turns on the high speed. that's all there is to it. it will come on at 1/2 and cool down to 1/4
                    • euroshark
                      • Apr 2006
                      • 3491
                      My dad has a fairly small fan on his 635 and it works pretty well... 12" I think.
                      • HST
                        • Jan 2006
                        • 757
                        I suggest a thin spal fan. There small one pull 1300 CFM.
                        16 inch Ultra Thin
                        2.05 inches thick
                        1378 cfm
                        $85.00 ea.
                        16 inch Mid-Performance Fan
                        Straight
                        1610 cfm
                        Mid-Performance fans are 2.48 inches thick.
                        $100.00 ea.
                        Available here
                        I'm sure you could find them cheaper if you looked around on the interwebs.
                        Originally posted by KingB
                        Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                        • PeaveyBassist
                          • Sep 2004
                          • 3511
                          The fan switch DOES have something to do with you finding fans. You're looking for something to help keep the car cool... the m42 switch turns the aux fan on earlier. Make it so when it is supposed to come on low, it comes on high instead. I have my car like this and it NEVER gets hot. Even after running for an hour straight with 6 autox runs in there during that hour on an 85+ degree day. Get the switch, keep the mechanical fan off and youll be fine.
                          Will
                          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                          Welcome e30 (brilliantrot '90 325is) 12/23/06
                          DaveCN = Old Man
                          My signature picture was taken by ME! Not by anyone else!
                          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                            The aux fan is only enabled if A/C is selected. In high ambients it alone may be insufficient if you've removed the engine driven fan. Adding a 1600cfm (or more) electric fan and controlling it with an 80-82C thermoswitch would be the right solution.
                            • JGood
                              • Jan 2004
                              • 7959
                              I went to Autozone, bought their 12" or 14" universal fan and a thermostat kit for a total of like $80. Takes 10 minutes to install and has a fully adjustable thermostat, with a probe that goes onto/into your radiator.
                              It's been working on my 325e for about 2 years, so I installed one in my 325is a few days ago. I don't have A/C in either car, so I installed it as a pusher in front of the radiator.
                              I can do anything I want in the front of the engine, with no fan there. There's a LOT of room. Sometimes I invite friends and have a cookout right in front of the timing belt, we play football and stuff in the big open space behind the radiator.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
