Brake booster?
  • oskard
    • 58
    Originally posted by M-technik-3
    You've made a clearance adjustment and if you have any engine rock the intake will hit your booster.
    my engine will never 'rock' that much man dont be silly :)
    check booster clearance on a e36 323i for an example.. there aint much booster
    clearance there.
    • oskard
      • 58
      and this is also what Zionsville did with their 3,2 liter conversion exept they used
      the 3,0 liter intake manifold and the stock booster :)
      • mirror
        • Apr 2004
        • 34
        Hem...wonder which engine mounting did you using for the conversion and yes I would like to see more picture of your engine bay..Thanks.
        • Bryson
          • 1490
          did you shim the driver's side motor mount? Did you use e36 motor mount brackets? e28 motor mounts? i'm curious about this, especially since the non-vanos motors don't have those fins in the first place (no shaving needed)
          • mirror
            • Apr 2004
            • 34
            Please share with us which engine mounting and alloy mounting did you use for that....
            remember we all love e30. E30 for life...forever please share with US.
            As far as I know VANOS engine also came with fins manifol.
            Thanks.
            • oskard
              • 58
              my engine is from a '95 525iX.
              I used the e36 engine mounts on both sides
              then i used a m20 motormount on the passenger side and a e28 motormount
              on the drivers side.
              I'll take some pictures today and post them here :)
              The only downside to this solution is that you need a e36 or e34 gearbox
              the e30 gearbox will not work.
              • Bryson
                • 1490
                the m20 motor mount explains why it fits, it's a bit lower than the e28 mounts, but the last thing i'd want to do is lower the motor with the oil pan being so low and the exhaust having to clear the subframe
                i'm running a getrag 260 (e30 325i tranmission) in two cars without problems
                  • 34844
                  Originally posted by Stu Mc
                  Nando, the brake booster is easy. It's the custom oil pan that you should be worrying about. ;)
                  i've seen pictures of it done though, and it's really not a big deal. you basically need an E34 M50 oil pan and an ix pan, a hacksaw and a tig welder. :twisted: Engine mounts I'm not sure of, but I've done swaps before that required custom mounts so that shouldn't be a huge issue. the engine will bolt right onto the tranny, the ix uses the same transmission as all other E30s, except for the ouput shaft of course.
                  The real question is, will I ever have $1500-$2000 lying around to do a motor swap. I'm thinking not anytime soon, I'd rather spend $1500 on a 5 speed!
                  • oskard
                    • 58
                    The pan is about 10cm from the ground and i have 60mm lowering springs in the car
                    so that does not worry me.
                    Here are some pictures :)
                    Drivers side:
                    Passanger side:
                    Looking good :) :
                    Here you can see that a e30 gearbox is a no go :?
                    Well i tried my best to shake the engine enough to hit the booster (and i'm a big guy:))
                    and it never got close to hitting it :D
