z3 shifter sitting a bit forward
  • dlmrun2002
    • Apr 2007
    • 808
    Just put in a z3 shifter and top gears( r 1 3 5) seems to close on the front while and 2nd and 4 th sit in the middle. Did I put it in backwards.? I put it with the bend to the rear. I wonder if it spun around on me before I hooked it up..
    DLM
  • dark89e30
    • 263
    Yeah, its just backwards...
    • dlmrun2002
      • Apr 2007
      • 808
      Did you make the same mistake?
      Funny-- I think it was the one clip that made me overlook the in car shifter profile. Thing took 1/2 an hour to get right..
      DLM
      • thereisnoyun
        • Feb 2007
        • 2301
        uh...
        .... does it even fit backwards?
        • dark89e30
          • 263
          Yeah, I've done it...
            • 34847
            uhm, do you have the z3 1.9 shifter? if so, it's *supposed* to sit forward...
            • dlmrun2002
              • Apr 2007
              • 808
              hmmm feels " way" forward"
              As I said in original post, 2nd and 4th gear sit just about where the original shifter neutral was. Feels a little off to me. I could have sworn I put the bend facing backwards and I would be suprised if it spun around on me. I got it set in it's white plastic mount bushing, clicked it in and went under and connected to linkage. Will have to check it out when I get back from Philly Livestrong Challenge..
              DLM :loco:
                • 34847
                yeah, that's how the Z3 1.9 shifter is.
                • Lodsin
                  • Sep 2006
                  • 734
                  If you read up on it a bunch of people bend the rod at the ball so it sits in the normal position.
