225/45/16 tire fitment?
  • tobybmw
    • 453
    I need new tires. I am considering 205/50-16 Conti. Sport Contact 2 or Bridgestone 225/45-16.
    I have 16x7.5 wheels with a 25mm offset. Would the 225/45-16 tires fit with an H&R sportsuspension? I have mixed reviews if they will fit even with hard cornering. Your opinions are always welcomed.
    Andy
  • LikeCDoos
    • Jan 2004
    • 2522
    go 225's, they look sexy on e30's. if you've got minor rubbing issues it's worth it.
    • Digitalwave
      is a poseur
      • 6300
      With that suspension and rim setup, you should be ok with 225/45-16.
      RISING EDGE
      • LowR3V'in
        • 4209
        205 is way too skinny
        If 225 fits, do it! :shock:
        • LikeCDoos
          • Jan 2004
          • 2522
          ya i've got 205's on right now, but get the job done without rubbing but just look way too skinny IMO
          • tobybmw
            • 453
            Does anyone have any pictures of 225 45 16 rubber on their car?
            Thanks for the thoughts guys.
            Andy
            • bimmerlover
              • 424
              Bill has 225/50 15s. Not quite the same.. but regardless, the 225s look AWESOME on his 318. His car also way out-handles both of mine!
              Here's a link to a post with pictures and info: http://www.r3vlimited.com/phpBB2/vie...ghlight=wheels
              • E30-323ti
                • 328
                I've been running 225/45 16's ET28 on the rear for months no rubbing issues at all.
                check link in sig for pics.
                292rwhp E30 :D
                • Jon325i
                  • 6934
                  Not every brand of a 225/45-16 tire may fit. I know that Yokohama should be ok.....ditto with Dunlops. However Bridgestone tires (like the SO3s...if avail in that size), is likely to rub due to the wider mid-section of the tire.
                  I think you should go for it. It will certainly fill out the wheel wells nicely ;)
                  Jon
                  Rides...
                  1991 325i - sold :(
                  2004 2WD Frontier King Cab
                  RIP #17 Jules Bianchi
                  • Ryan Stewart
                    I Love Miatas
                    • 8978
                    Ive got 225 Yoks up front and 245 in the rear. They fit fine and have only rubbed on the plastic when I hit a bump that sends me flyin.
                    Mine are a similar offset at 28 so you should be just right there at the lip.
                    Im now E30less.
                    • rs4pro3
                      • 5808
                      What about with et-20 rims in 16*7.5" I was looing right now I've got 205 but I doubt I could squeze 225 in the rear, maybe in the front.
                      85 325e 2.7 ITB'd stroker
                      • Rob
                        • 8166
                        I find that hysterical.
                        BEERTECH
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          as do I
                          • BavarianBimmer
                            • 951
                            225/45r16 in front
                            225/55r16 in rear
                            1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                            1997 E36 328iT
                            1990 E30 325iT 24v SOLD
                            1989 E30 325i 2.7i M-Technic II SOLD
                            • chesster6969
                              • 321
                              Any side and rear pictures?
                              You have the higher rear arches so you can fit more tire in there.
                              Did you roll the rear fenders or cut the fronts at all?
