Keyless entry help
  • nateb
    • Apr 2004
    • 54
    Keyless entry help
    I'm having trouble finding the lock and unlock wires located behind the drivers side speaker panel. The following URL goes to a thread of mine on bimmerforums where I got most of my information http://forums.bimmerforums.com/forum...59#post2290559
    The very last post describes my current status.
    If anyone knows anything about these wires in questions I would appreciate any help.
    Thanks
    -nate-
  • Bill 84 318i
    • 1600
    Go by the wiring directions that came with the kit.
    I did mine exactly with the wires that they told me to (after I double checked in the Bentley) and it worked fine. For like 5 minutes, then it stopped working and I have no idea why.
    • nateb
      • Apr 2004
      • 54
      I am following the directions as far as I can tell. Just to clarify, what locking system do we have? The instructions describe 4 different types of locking systems.
      Which wires did you use to lock and unlock your car?
      Thanks
      -nate-
      • Ryan Stewart
        I Love Miatas
        • 8978
        crap its been so long i camt remember, blue and green I think.
        go to the12volt.com and look at thier wiring colors for an 83 320i. Its the same and its correct.
        If you have soldering skills solder and heat shrink them, then you will never have to worry about them coming loose or corroding.
        Im now E30less.
        • LikeCDoos
          • Jan 2004
          • 2522
          What brands of keyless entry systems did you guys get...i really would like to do this over summer. How much do they cost.
          • nateb
            • Apr 2004
            • 54
            I'm currently installing the Stellar ST8000 that i got for $100 from mustangdepot.com.
            I'm very close to completion at this point.
            Ryan,
            Thanks for the info. I will check that diagram. I used a different one from the12volt.com before.
            bbs
            -nate-
            • nateb
              • Apr 2004
              • 54
              Ryan,
              The 83 320i didn't have anything listed for lock and unlock wires. I have it all done except for locking and unlocking.
              My diagram says nothing about using external relays or other electrical components to get the locking and unlocking working. It seems that all I need to do is tap into the wires. I was told to do nothing with the lock and unlock NC wires as outlined on my bimmerforums thread.
              -nate-
              • Ryan Stewart
                I Love Miatas
                • 8978
                Crap, mybad they have changed the site. It used to have the wire colors.
                I used external relays to protect the alarm brain. LIttle 3 amp ones from Radio shack were soo cheap its like "why not?"
                I cant go pulling the module to look at how I wire d mine up right now. After I get the two hard finals out of the way I can do it tho.
                Im now E30less.
                  • 34839
                  mine is wired in the trunk. I'd put it there.. it's super easy to get to and the trunk lock is also a master lock like the drivers door.
                  • Ryan Stewart
                    I Love Miatas
                    • 8978
                    Yes that would be easy if you are JUST doing remote entry because you could use the wires to the gaslid lock. The only downside is integrating it into the parking lights for flashing and the horn for alarm and getting ignition signal.
                    Im now E30less.
                    • nateb
                      • Apr 2004
                      • 54
                      I got it all working. It turns out I had the wrong wire connected to the ground. The stellar st8000 uses a brown/blue and a brown which I had mixed up.
                      The system works great. I'm very happy with the results.
                      My rear red sidemarkers don't seem to flash with the rest of the system. At this point I'm not sure if its supposed to be like that or not but I would like to get them flashing at some point.
                      Thanks for all the help.
                      • christophbmw
                        • Mar 2004
                        • 363
                        www.autoloc.com or www.bmpd.com they bothj sell the same one for $90 bucks. ive had mine for 2 years now and it works fine. i love it. very easy to install, took about 10 minutes.
                        '91 318is
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          what is the difference between this one:
                          http://www.autoloc.com/detail.lasso?itemid=KL600
                          and this one:
                          http://www.autoloc.com/detail.lasso?itemid=KL550
                          • nateb
                            • Apr 2004
                            • 54
                            One has 6 channels of output and one has only 5. The extra channel on the KL600 could be another trigger wire or another control wire, it doesn't really say. For the same price I would get teh KL600.
                            -nate-
