Hmm no rev limiter?
  • Yakinho
    • Feb 2007
    • 650
    Hmm no rev limiter?
    Yeah, so every once and a while when I push the shit out of my car i run into an interesting issue. First, my clutch slave and master cylinders need to be replaced, along with my whole shift assembly as i have 4+ inches of play in gear, but anyway... So i floor it, shift to second, am clearly in second but get the wonderful sound (and vibration) of my gears grinding (at this point my foots already back on the gas because I don't assume my clutch is THAT fucked. So i took a look at my RPM as my car was SCREAMING and i'm wayyyyyy the hell passed 7k, i'm shifting at 15 miles per gallon.:down: Now the only other time its reved this high was when I did the same thing a while back and blew a shit load of carbon out of the exhaust, that time the rpm needly bounced fully around the gauge. Interesting. So my question in short: Why do I have no rev limiter?
    Thanks.
  • rs4pro3
    • 5808
    sounds more like your tach is off. My 88 325is used to do this randomly the tach would read 1k rpm's too high.
    85 325e 2.7 ITB'd stroker
    • Yakinho
      • Feb 2007
      • 650
      Yeah, I do believe my tach is off. I generally shift at 3.5k, it doesn't sound strained at all, and I idle at 1.1k...
      • strad
        • Jan 2007
        • 241
        It's possible that the above is true. It's also possible that your DME has an aftermarket chip in it. I know for sure that my 92 has a stock chip, and I have bounced off the rev limiter on one occasion -- at about 6300 rpms, maybe a tiny bit higher. Can't tell you for sure, since I wasn't paying attention to the tach at the time (which is the whole reason the event occurred lol!). I was paying attention to that damned chipped M42 vert in the next lane :o
        The current fleet:
        1992 325ic: 148k-171k miles
        1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
        1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
        • Yakinho
          • Feb 2007
          • 650
          Is there a top speed limiter in these cars? Laser read 137, friends audi read 138, my speedo said 150+.... (not right, speedo is weird.) The car was definitely screaming
          • strad
            • Jan 2007
            • 241
            Yes, it's like 125 mph. Can be removed with a chip.
            The current fleet:
            • thereisnoyun
              • Feb 2007
              • 2301
              rev limiter
              thats funny, cause my rev limiter only happens at 1st gear. I can rev past 6000 on any but the first. So wierd..
                • 34847
                on later cars, yes, but not all E30s had them. and a chip doesn't remove it either..
