325e same headers as 325i?
  • golde30
    • 11464
    hey i was just wondering, does the 325e use the same headers as a 325i, or are the mounts going to be different. i found a nice set of bavarian headers online, but they are for a 325e...
    IG: @Baye30
  • modifiede30
    • 1208
    I thought they were shaped differently to account for the lack of an oil distribution block on the eta. I would assume that if this is the only difference, they'd work since the head castings should be the same except oil passages.
    Driving is the only way to go faster....
    • Ryan Stewart
      I Love Miatas
      • 8978
      same, not sure what hes talking about on the oil. The ports might be slightly larger on the 325i.
      Im now E30less.
      • rs4pro3
        • 5808
        Ports are larger on the 325i manifolds then the 325e manifolds.
        85 325e 2.7 ITB'd stroker
        • X2theZ3
          • Mar 2004
          • 932
          also the "i" headers empty into 2 exhaust pipes while the "e" empties into 1.
          • Jordan
            • 12912
            He isnt talking about stock manifolds dumbasses. He is talking about the headers that Bavarian Auto sells.
            I would imagine the headers for the 325e and 325i are the same. Why dont you call bavauto and find out?
            https://mtechniqueabs.com/
            • X2theZ3
              • Mar 2004
              • 932
              The "i" headers are different than the "e" headers just like I mentioned. The exhausts are different.
              • golde30
                • 11464
                yes, i think i will call bav auto....why didnt i think of that before... :zzz:
                IG: @Baye30
                • X2theZ3
                  • Mar 2004
                  • 932
                  Yes, that would be wisest, You would be downgrading if you used the "e" headers on the "i."
                  • golde30
                    • 11464
                    that doesnt matter, the bav auto headers go 3-1, 3-1, then they go into 1 at the end, which can be cut off to use on an i model...im more concerned with the headers actually mounting up to the head and not having any clearance issures...
                    IG: @Baye30
                    • golde30
                      • 11464
                      damn u get off my thread, you dont know what you are talking about...im not reffering to stock headers, these are aftermarket performance headers...damn
                      IG: @Baye30
                      • X2theZ3
                        • Mar 2004
                        • 932
                        Well in that case, they bolt to the head with no problems. Check with bavauto if you want to be "sure."
                        • X2theZ3
                          • Mar 2004
                          • 932
                          Jeeze don't get butt hurt. I'll get off your sorry thread. I know exactly what you're talking.
                          Oh wait no i don't. I only have the bavauto ones. Sorry genius.
                          Think about it. If it was the same exact part then wouldn't it have the same part number.
                          32 020 C "e" headers
                          32 019 C "i" headers Like I said before. They are the same on the head side, different on the exhaust side.
                          • golde30
                            • 11464
                            if the only difference is that lil piece on the end, then why would it be a downgrade? BTW, i see that you edited your earlier post to make it look like you were clear on this in the first place...nice try, but i read the origional and it made no sense, which is why i was getting irritated with your replies in the first place.
                            IG: @Baye30
                            • X2theZ3
                              • Mar 2004
                              • 932
                              Edited as in added not chaged. It would be a downgrade if you didn't cut the headers and use the "i" exhaust. The downgrade would be bolting them to an "e" exhaust.
