Rubber fuel line...
  • wagonizzle
    • Sep 2006
    • 443
    Rubber fuel line...
    So my car died on Monday night, and a friendly tow and quick diagnosis later, we determined the fuel pump to be bad. Got the new pump all situated, should be fine. Decided I may as well change the filter as well, but when I raised the car to get it out, I noticed the little rubber line that sits behind the filter (farther up towards the rear seat) has surface cracks. I am only interested in taking the filter out once, and figure I should probably replace all the rubber lines. Realoem says 8x13mm. Does this basically mean I need to grab 8mm OD hose, and just cut the pieces I need? I'm sure I can get that anywheres... let me know what you guys did.
    Originally posted by chileelky
    amaze about the enthusiasm e30 generate
  • whowhatwhere
    • Aug 2007
    • 259
    You better get 8mm ID
      • 37833
      Make sure you get fuel injection hose when you do buy it.
      Grover Beach, California
      BimmerHeads.com
      • wagonizzle
        • Sep 2006
        • 443
        BMA lists 8mmOD rubber, and 12mmOD cloth covered fuel hose. The hoses in there now are rubber...
          • 34844
          they have to be hose rated for fuel. you can't just use any rubber hose in there.. vaccum hose won't hold up to having gasoline in it.
          • Rigmaster
            • 3464
            The most important thing is- (as MR 325 mentioned)- make sure you get Fuel Injection hose, NOT just regular fuel hose. Your car may end up dying a firey death if you use regular fuel hose.
            And yes, it's 8mm ID x 13mm OD.
            Bret
            BMW part #13311272731 (for reference)- usually sold by the meter for ~$7-9 per
            • wagonizzle
              • Sep 2006
              • 443
              Oh, I got that, for shizzle. I just wanted to find out the actual sizing of the hose before I take it all apart and have a car that doesn't run. Kinda hard to go to the store after that. If it only has to be close in diameter, that is fine. I've never done this before and want to have the right parts in hand before I pull the filter out. I feel kinda dumb asking this, but there doesn't seem to be a fast easy answer in Bentley, BMA, Pelican, etc.
              edit - ok, 8mmID, 13mmOD - that's what I needed. Thanks. Didn't realize that's what the realoem designation meant.
              • FredK
                • 14762
                5/16" SAE 30R9 fuel injection hose at your local parts store will work as well. It is only off by .06 mm in diameter. Which is .002". Which is well within the manufacturing tolerance of 8mm fuel line.
                  • 37833
                  Yup, I have 5/16" hose on my car.
                  BimmerHeads.com
                  • NC325iC
                    • Mar 2004
                    • 6565
                    same, but as stated twice above make sure it is pressure rated hose
