HELP with Fuel Pump Hard-Wire (PIC inside)...
  • TurboMeTroy
    • Nov 2004
    • 184
    Ha - Well...difficult start ups and doesn't exactly run like a finely-tuned piece of German machinery like it should. I replaced the: coil, plugs, Wires, Distrb., Air filter...and thought the fuel system might need some attention...so I going to just hard wire the pump to ensure the pump is working and see if it made the car run any smoother if I had the peace of mind that fuel pump was indeed pumping ...and the relay would be bypassed.
    • DaveSmed
      • Apr 2007
      • 1407
      Give this trick a whirl, much less likely to result in fireworks, and you don't need to cut or rig anything.
      eww. dirty relays.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • DaveSmed
        • Apr 2007
        • 1407
        BTW, you have two fuel pumps. The in tank one is a low pressure transfer pump, and the one under the car, in front of the LR wheel is the high pressure main pump. (right above the fuel filter) They both should make some sort of noise with that fuse in there.
        -Dave
        • TurboMeTroy
          • Nov 2004
          • 184
          Cool - Thanks!
          Any...zoomed out shots?
            • 34844
            that's a great idea dave. I have a whole bag of fuses I could use for something like this..
            • TurboMeTroy
              • Nov 2004
              • 184
              here goes it...should I document this? ;)
              • DaveSmed
                • Apr 2007
                • 1407
                Originally posted by TurboMeTroy
                Cool - Thanks!
                Sure, what do you need a zoomed out shot of? I just grabbed those real quick as I was posting. Oh, document it up, never know when it might help someone else.
                Nando, that fuse has some mileage on it, very handy for testing stuff especially the damn fuel pumps that are hot on crank/run only. I have some other neat creations too, like a two prong 110v plug and some wire attatched to a fuse. One of the blades is twisted 90 degrees and it works great for most normal relays where 30 and 87 are at opposite ends of the relay. That comes in real handy as well.
                -Dave
                • crxb16t
                  • May 2007
                  • 79
                  eww. dirty relays.
                  Thats why i relocated mine. Make my engine bay look purdy. +1 on the bent fuse trick, -1 on losing at least 10 30 amp fuses in my garage lolz
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    Says the man who seemed to enjoy having a working blower motor the other night.... ;)
                    -Dave
