VDO vs Motometer
  • ldsbeaker
    • Aug 2004
    • 3098
    Well, it didn't work for me.
    Slicktop City!
    • lordofthewaters
      • Oct 2005
      • 714
      Are you sure the battery light worked? If the bulb was shot it'll do stuff like that.
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • ldsbeaker
        • Aug 2004
        • 3098
        ??? Everything lit up the way it was supposed to. Everything else worked but the tach.
        Slicktop City!
        • Aviator
          • 616
          Bringing an ancient thread back from the dead sorry.
          I have an 84 e that has a vdo cluster and the temp gauge is inop and the batteries are toast. Which I think is causing a battery drain. Anyway I bought a great shape motometer cluster since I'm doing an m50 swap. Well I obviously didnt do any research on the cluster swap. Can I use the motometer cluster or at least take the tach, batteries and temp guage of the motometer and put it on the vdo?
          84 325e Burgundrot S52 M Tech 1.
          http://www.r3vlimited.com/board/showthread.php?t=250109
          • AndrewBird
            The Mad Scientist
            • 11898
            See here:
            • Aviator
              • 616
              Ok so I guess since the one that's in my car is before 86 I can't interchange. Looks like I'll have to send it to Greg to rebuild it then. And sell this motometer one that I bought.
              • fresh_TD
                • Aug 2013
                • 2457
                can I do a direct swap with a late model motometer cluster for my late model VDO cluster.. I currently have a VDO but want to swap in a MotorMeter one
                '91 318i (Alpine) - daily
                '88 325ix (Zinno) - drive here and there!
                • cabriodster87
                  • Jan 2011
                  • 1042
                  I have a motometer/vdo swap with no problems.
                  Reich und Roll!
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    Direct swap..nothing additional?
                    Sent from my Samsung Note 4
                    • cabriodster87
                      • Jan 2011
                      • 1042
                      Yes..no?
                      Reich und Roll!
                      • SLUCK
                        • Nov 2007
                        • 344
                        Resurrect for help. I'm very confused on this topic.i have an 84 318i, the battery light stopped working and is preventing my alt from charger the battery. (Swapped the bulb still no good). I've been told I need to get a late model like 91 cluster to put in because of a heat sink that prevented that from happening in later models. So as long as I get a 91 vdo cluster (currently have vdo) it will work and fix my problem.
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          From everything I've read you can swap anything among clusters as long as you don't cross the line between early and late (best determined by the number of red SI lights).
                          I do believe the bulb circuit fires up the alternator but the bulb alone is not the only potential culprit. Could be the circuit board, a bad wire or perhaps your SI batteries. Someone (Greg ?) will pipe in soon enough.
                          Alice the Time Capsule
                          • SLUCK
                            • Nov 2007
                            • 344
                            Yeah, I had my bulb go out and I replaced it but it won't come on now and I've gotta jump the car every couple days. It's getting frustrating. I've only taken it to a Midas for the work and they said the only way to get a new board was to have bmw build it for $1800
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              We all know that Midas is the ultimate expert on e30 repair
                              Seriously, used clusters are readily available or better yet, contact Greg at Bavarian Restoration (gregm on here) and he can hook you up.
                              • Das Delfin
                                • Sep 2014
                                • 2293
                                Try working with the bulb a bit. Sometimes you have to bend the leads so they make contact with the fixture. I would try this first
