Can i run spacers with 14" basketweaves?
  • rwh11385
    lance_entities
    • 18403
    I'm running my stock weaves right now, but I definately don't dig how far away the wheel is from the rear fender. Also, my 15" Type C's need about 5-6mm spacers to run 225s, so I might as well get them.
    Can I run 5-6mm spacers on stock basketweaves?
  • Spaz
    Crazy Canuck
    • 2276
    i don;t see the harm in doing so, its very popular over the pond to space the wheels flush with the fenders.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • Bill 84 318i
      • 1600
      Why wouldn't you be able to run spacers on them? I don't get the question.
      Don't forget longer lugbolts if you do.
      • rwh11385
        lance_entities
        • 18403
        Bill, I'm just making sure before I throw down $$. I just don't assume anything anymore.
        I am tempted to opt for a stud kit.....but wheel changes aren't that big of a pain. Maybe if someone sold me his.
        • randywalters
          • 399
          Re: Can i run spacers with 14" basketweaves?
          If you use 5mm spacers they'll push you wheels out just enough that they will no longer be centered by the hub and you'll get a shimmy through the steering wheel. BTDT. I wouldn't do it unless you don't mind having a shimmy on the highway.
          Randy Walters
          2021 Mazda 3 Sedan Premium AWD
          1988 325is (w/89 bumpers, recently sold)
          1989 325is (Broadsided long ago RIP)
          1996 328is (Sold to Matt J)
          2003 530i Sport (Spare car now)
          2005 X3 (little woman's car)
          Driving Instructor BMW CCA L.A. & S.D. Chapters
          Multiple L.A. & S.D. Region SCCA Autocross Championships
          • rwh11385
            lance_entities
            • 18403
            What if I use those hubcentric centering rings or whatnot that people recommend from tirerack or other places.
            See Bill. I wanted to check for a reason. :P
            • Bill 84 318i
              • 1600
              I think you'd have a little hub left if you stuck to 5mm spacers. If you go 8, then you're looking for trouble. There's a little more hub in the fron than in the rear as well.
              Hub centering rings are not that at all. Hub centering rings fit inside the hub bore of generic wheels so that they will fit snug on the 57.1mm hubs of e30's. You might be able to find hub extenders somewhere, like TMS, but I'm pretty sure they only have them for the bigger hubs that came on the 5 lug cars.
              • randywalters
                • 399
                There's not enough hub projection to reach the centerbore if you use the 5mm spacers. I tried it on my car with various wheels and i could see inside the center of the wheel that there was a small gap between the chamfer of the centerbore and the raised hub. No matter which wheels i tried, i got a shimmy with the 5mm spacers which went away when i removed the spacers.
                Randy Walters
                • Bill 84 318i
                  • 1600
                  I always thought there was a fair amount more than 5mm of hub exposed, but could be wrong.
                  Was there ample hub left exposed when using 5mm spacers in the rear?
                  • randywalters
                    • 399
                    I always thought there was a fair amount more than 5mm of hub exposed, but could be wrong. Was there ample hub left exposed when using 5mm spacers in the rear?
                    The hub does stick out more than 5mm, but the inside edge of the wheel's centerbore has a tapered chamfer so the centering portion of the centerbore is further in - it's not right up to the edge of the mounting surface (all my wheels have some amount of tapered chamfer) and that on top of the 5mm spacers renders the wheel non-hubcentric.
                    Randy Walters
                    • Ryan Stewart
                      I Love Miatas
                      • 8978
                      you have less hub in the rear bill? I can get away with ONLY 3mm on the front with the Alpinas if I wanted to but my rear hub is like 1/2".
                      Im now E30less.
                      • Digitalwave
                        is a poseur
                        • 6293
                        If you have 195 width tires, you could probably run up to a 15mm spacer with those rims.
                        RISING EDGE
                        • decay
                          • 5637
                          mine don't do that.
                          past:
                          1989 325is (learner shitbox)
                          1986 325e (turbo dorito)
                          1991 318ic (5-lug ITB)
                          1985 323i baur
                          current:
                          • Bill 84 318i
                            • 1600
                            Nah, more hub in the rear. That sounds funny.
                            • e30evolution
                              West Werks
                              • 1888
                              in the front your SAI would get messed up and your tires would feather.... not a big deal tho....
                              ummm.... some spacers have a lip on them that can center the wheel.... but other wise just torque the wheels off of the ground and make sure to do it in a cross pattern, then the lugs will center the wheel
                              http://www.westwerksauto.com
