tailight "illumination" upgrades :)
  • fporro
    • 1860
    hey guys,
    did a little upgrade to my tailights back covers.
    now i have a bright cargo area and an extra set of brake lights ..
    also posted a set on ebay ... http://cgi.ebay.com/ebaymotors/ws/eB...tem=7905015229
  • Spencer
    • 767
    That's cool.
    So, you need to have the rear lights on to get the brighter trunkspace?
    Specer
    • Ryan Stewart
      I Love Miatas
      • 8978
      on my brake light holder the back part has a clearish section so the parking lights shine into the trunk when they are on.
      Im now E30less.
      • fporro
        • 1860
        yes Randy, that's basically "IT".
        i just added an extra light by tapping and runing wire and tab from donor back piece to second sockeket from left, it looks like this (yet to modify this one) ...
        • BMW BMXER
          • 2325
          Me too.
          Sold it.
          • e30evolution
            West Werks
            • 1888
            that is definatly pretty cool...
            has anyone here wired up the rear fog light?
            http://www.westwerksauto.com
            • bimmerphile
              • 3495
              Franz and Viet both have.
              • matt325is
                • 409
                Thats a tight idea!
                I have euro rear fogs wired up (a little fabrication of the connector/metal board in the cover..)
                matt
                • e30Matt
                  • 5077
                  Were there two different types of the bulb holders? I ask because my friend's '91 318is has a different piece with the "rods", while mine seems to have "plates."
                  • AngelsToy
                    • Apr 2004
                    • 27
                    i updated my rear fogs to blink with my blinkers. i went to a junk yard and found a beemer with rear tails and took a wire set from it and just added into the empty hole where the foglights go. i have it wired upto the wire bracket on bolth the male and female sides. it was pretty easy. right now i just have it spliced into the blinkers. i tried all the methods.. hooking them up to the brakes, parking lights, ect.. i t hought the blinkers were the coolest so i stayed with them. in the future i want to get a relay to make the blinkers blink as following. fog, blinker, side blinker. right now it's fog&blinker, side blinker. (with the lights on) hopefully i'l figure out how to wire it up since it might be a task with the side blinkers. just some ideas from me. :]
                    • nzer
                      • 122
                      You guys don't have rear fogs that turn on?
                      • fporro
                        • 1860
                        hi guys,
                        is an oem part, it came in various e30 models, part number 368 425 030 130 but is same for othe 2 versions without "window"
                        i also tought of using dios and different functions but decited to go simple since i usually brake more things than i actually fix/upgrade
                        notice that brake lights are brighter that "lights", also you can probly see inner light shining through plastic window.
                        there's still is an empty slot at pin/connector locations, have not look at actual harness plug but perhaps original "Fog" light wire it's there.
                        in case i need to use extra illumination then i just leave parking lights on until finish unloading, besides that is a cosmetic upgrade (at least for the inside)
                        once found a set of kick panels that someone added glove-box (square type) lights to them, they illuminated at same time as dome lights., pretty nice.
                        here's pic of them in action, also a shot from my local mntnbike trail atop malibu.
                        (2,600ft on 4.5 miles, usually hit about 50 on it :) )
                        • Digitalwave
                          is a poseur
                          • 6300
                          Wow, BEAUTIFUL bike, how much did that cost you?
                          RISING EDGE
                          • fporro
                            • 1860
                            the Norco about $ 100 a pound, she comes in at 35+ lbs, not bad for 5+" travel.
                            there's other meat cuts at about $ 200 a pound sprinkled it Ti Dust such as my road ride.
                            she's just 20 lbs, could got lighter but wheels are heavy yet slices through the wind like no other :) ...
                            • nateb
                              • Apr 2004
                              • 54
                              Thas a niftly little taillight upgrade. Thanks for the info Frank!!
                              -nate-
