If your O2 sensor relay does not work...
  • smcdermott326
    • Jan 2008
    • 84
    What will be the symptoms of the relay not doing it's job? Poor fuel economy or is there more to it?
  • AlpineIS
    • 161
    A relay operates much like a switch. If it is not functioning, the 02 sensor will have no current flow and will not operate. A faulty or non-operational O2 sensor will cause the engine to run rich (more fuel), which in turn will hinder fuel economy.
      I sort of think that relay is only for the O2 sensor heater. If it is bad it only delays full operation of the O2 sensor.
      • AlarmedBread
        • Sep 2006
        • 1510
        When mine was going bad.
        CEL at idle, blip throttle it goes away, no CEL from 1500-2900, at 3000 the engine would cut out, stutter, CEL, then rev up again with the CEL flickering.
        It was running very rich and falling on it's face from nearly flooding as best I could tell.
        • 328ijunkie
          • May 2007
          • 3961
          What if i have the CEL at idle, blip (with severe hesitation) and it goes away and stays away... Same thing?
          Check Us out on Facebook
          Full Product Line Tuning
          • Mike325
            • Mar 2006
            • 3685
            It is possible that it is the same. One other way to tell if your o2 is bad is to smell the exhaust. It would have a rich sulfer kinda smell to it if it is running rich.
            Originally posted by Kershaw
            • 328ijunkie
              • May 2007
              • 3961
              I dont have the sense of smell :( and my exhaust exits somewhere under the car for the most part anyway :(X2
                • 34844
                the relay is only for the heater circuit. without it, the sensor will take longer to warm up, and possibly not operate at a hot enough temperature during low load cruising and idle - the result is it won't be as accurate and possibly wear out faster.
                • 328ijunkie
                  • May 2007
                  • 3961
                  Yeah well i get a CEL at idle and poor off idle performance so... Im thinking thats my issue, that or the O2 Is dead all together...
                  • hendrixvodu
                    • Jan 2007
                    • 2514
                    im having a prob with mine....when mine is plugged in the car bucks very badly and cant idle at all....but when i unplug it the car runs fine???? any idea what that could be??????
                    and its a new sensor
                    -His-
                    87 e30 325i
                    87 e24 m6
                    05 e83 x3
                    94 e32 740i 5spd
                    -Hers-
                    89 e30 325i
                    18 f48 x1
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      My 85 318i did the exact same thing. My solution?............
                      Yank the m10 and prep for s52. Hope this helps.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Haha S52 FTW. Could be a bad connection or bad relay. When its unplugged the ECU just runs in open loop which is bad for fuel economy but yeah.
                        • hendrixvodu
                          • Jan 2007
                          • 2514
                          oh shit my s52 is on layaway .......damn sears!
                          -His-
                          87 e30 325i
                          87 e24 m6
                          05 e83 x3
                          94 e32 740i 5spd
                          -Hers-
                          89 e30 325i
                          18 f48 x1
