Just Got A 4.10 LSD, WHAT FLUID???
  • bimmerboy12
    • Jun 2004
    • 1057
    Hey all, just drove up to Lansing, MI and picked up a 4.10 LSD from an iX from AWDE30. I will be installing it in my 88 325i cabby. I know people have used 80W90 in these, but I have also heard that BMW is now recommending 75W140??? Should I also add some limited slip additive?
    Thanks in advance for your help!
    Brian
    1988 325iC Project - FINISHED!
    Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
  • erik325i
    • Jan 2005
    • 3567
    Redline 75w90 is the one that has the limited slip additive in it.
    -Erik
    • Teaguer
      • Sep 2004
      • 6167
      You really don't want to install an IX viscous diff in your car which should have a conventional clutch pack .
      And you really don't need limitied slip additive in them , regular 80/90 gear oil is fine .
        • 34844
        you don't need LS additive in the ix diff
        • bimmerboy12
          • Jun 2004
          • 1057
          Please elaborate. Why don't I want to put this in my cabrio???
            • 34844
            it'll be fine - as long as the VC isn't burned out. I'd say what, 2 people on this site have actually tried it? probably with fried VCs too. everyone else is just repeating what they read in a post from 3 years ago..
            • bimmerboy12
              • Jun 2004
              • 1057
              Sigh of relief. What is VC... viscous clutch? Is this just the clutch mechanism like any other limited slip unit? I understand that they wear out, just as a clutch on a drivetrain would. Thanks nando.
                • 34844
                it's similar, yes. they don't realy wear out, but they are more easily burned up - running different tire sizes, patterns, improper towing, etc.
                • bimmerboy12
                  • Jun 2004
                  • 1057
                  well lets hope this one is in good shape and performs well.
                  Just for my knowledge, is the iX VC different from the typical LSD? And how?
                  • e30Matt
                    • 5077
                    The iX diff is a viscous coupling diff. If you know how an automatic torque converter works, it's the same basic principle, using the resistance of the fluid passing through a series of vanes to control how much torque is transmitted.
                    The standard LSD uses a clutch pack setup consisting of multiple friction plates made of either steel or a friction material. The friction between the two dictates the amount of torque transmitted.
                    • blueapplesoda
                      • Dec 2005
                      • 1904
                      im not sure if this is a myth, but i remember my dad mumbling one about how he used to put a higher viscous rated oil in his VC diff and it supposedly gives it a little more "lock" but again i don't have any way to verify this. It would seem as if it would work, no?
                      • bimmerboy12
                        • Jun 2004
                        • 1057
                        Very interesting. So did I score something special with a VC IX lsd, or are the clutch pack type (like I have on my CJ7) more reliable/cheaper to repair?
                          • 34844
                          no, the VC is completely sealed - you can't change the fluid inside without cutting it open and welding it back together.
                          • kishg
                            • Sep 2006
                            • 2624
                            that's correct and there is no fluid inside. it is filled with silicone (yes, like in boob jobs). the viscosity of the silicone changes due to friction. more details here : http://home.earthlink.net/~wardellhi...ral/iXfaq.html
                            '12 F30 328i Sport Line
                            '91 SpecE30 #523
                            '00 Ford F-350 Dually Tow Vehicle
                            BMWCCA #360858 NASA #
                            128290
                            • bimmerboy12
                              • Jun 2004
                              • 1057
                              There is a seperate compartment filled with silicone fluid that is factory sealed, but the gears obviously take gear oil. correct?
                              The more I look into this, the more unsure I am about putting this in my cabrio...
                              Advice???
