Just Got A 4.10 LSD, WHAT FLUID???
  • kishg
    • Sep 2006
    • 2624
    Originally posted by bimmerboy12
    There is a seperate compartment filled with silicone fluid that is factory sealed, but the gears obviously take gear oil. correct?
    The more I look into this, the more unsure I am about putting this in my cabrio...
    Advice???
    thats correct. there is some confusion of the vc units (there are 2) with front and rear diffs in this thread. the diff's are clutch packs and will take oil. The auto ix has 4.10 diffs. Mine is an auto swapped to 5spd so retains it's 4.10 diffs. You should be fine swapping it in. I think it should be a direct bolt-in. Check the ix section on e30tech for more details as well.
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
      • 34844
      it will be fine - the only difference is the VC instead of a regular clutch pack.
      • Teaguer
        • Sep 2004
        • 6167
        Sure it will bolt in and work ....but it won't be ideal .
        I just tend to believe that the VC diff is not meant ot hold up to the torque of a standard 2wd drivetrain and will meet an early demise .
        In the IX the rear diff does not see as much torque coming through .
        Like I said ...it will work ..but BMW put a viscous diff in the IX and a more robust clutch LSD in all others for a reason .
        • bimmerboy12
          • Jun 2004
          • 1057
          great now Im completely unsure. I may just put this up on ebay and look for a standard clutch 4.10 lsd. What is the VC 4.10 lsd worth?
          1988 325iC Project - FINISHED!
          Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
          • 92 mtechnic cabrio
            • 4907
            late model S13 240sx comes with viscous LSD FYI
            R.I.P 07/01/09 - 04/23/10 :(
            • bimmerboy12
              • Jun 2004
              • 1057
              Is this your opinion or have you read this anywhere? Could it also be argued that the iX was BMW's flagship AWD traction machine and therefore "upgraded" to a viscous coupling? Just speculating and trying to get the facts. Any more thoughts on this subject would be greatly appreciated.
              Brian
              • Teaguer
                • Sep 2004
                • 6167
                Thats great but has no bearing whatsoever in this thread .
                Lots of other makes have viscous diffs .
                That is why I made it a point to say "BMW's VC diff" .
                Brian
                Well the reason and example I gave is my own opinion yes .
                But thinking that the IX was a flagship and therefore had a superior diff is just wishfull thinking on your part at best .
                It really all depends on your intentions with your vert after insatlling the viscous diff .
                Like I said sure it will bolt up and work ....if you just want to cruise around in your vert and feel better about having an LSD then sure it would be great for that .
                But if you have any kind spirited driving , donuts, drifts auto-x or whatever in mind then it won't work very long for you and you are better off getting a clutch LSD like all other non-IX BMW's have .
                Its not like a regular 4.10LSD is hard to find , they were standard on all 88.5 and later 325is automatics , an available option on all 88.5 and later 325i automatics and standard on all US M3's .
                • bimmerboy12
                  • Jun 2004
                  • 1057
                  Like I said, just speculating. I won't be doing donuts or drifts or anything like that, I guess I drive sort of hard. The main reason I want this is for snow traction. We get snow and ice although in small amounts, and my cabby absolutely BLOWS in it. However, my wife's 328iC does awesome with an LSD. When i am able to go forward at a stop sign on level ground with a smattering of snow, THEN I will feel better about having an LSD.
                  Any idea about what my LSD is worth?
                    • 34844
                    this is how I read your post:
                    "blah blah blah blah, I'm just making this up as I go."
                    it will be fine. won't hold up to autox, track etc? huh? what's your basis for this statement?
                    yes, BMW put clutch packs into the other E30s for a reason - cost.
                    • Teaguer
                      • Sep 2004
                      • 6167
                      Ok I can see you are going to try and defend the IX and all but come on ...you gotta be for real .
                      How many non-IX E30's have you heard of that auto-x or track with an viscous diff ?
                      I'll tell you , NONE .
                      I personally would never install a IX viscous diff in any of my cars for the resons that I have already given .
                      • bimmerboy12
                        • Jun 2004
                        • 1057
                        Another point is that i know 2 guys who autox and track with ix's... and specifically got ix's over is's for that purpose. Im gonna put it in and hold on to my open 3.73 just in case.
                        Will I have to detach my A-arms to get the half shafts out?
                        • e30Matt
                          • 5077
                          Nope, just unbolt them from the diff and they'll drop right down.
                          • bimmerboy12
                            • Jun 2004
                            • 1057
                            Hey all, put this in and it works great. What a difference! I can drive where I NEVER would have been able to before in snow and ice. Don't notice much difference in the gearing from a 3.73 to a 4.10.
                            • AWDE30
                              • Jul 2006
                              • 762
                              Just saw this. Glad it worked.
                              • 87e30
                                • Jul 2008
                                • 5676
                                good thread. seriously.
                                I just hate everyone.
                                No need for discretion.
