running rich
  • E30_fiend
    • Apr 2006
    • 7348
    running rich
    Well I was informed yesterday night that when I shift from 2nd to 3rd and 3rd to 4th, there is an abundance of carbon that comes out of the exhaust. Now where can I start looking in order to lean it out?
    FYI, I'm running 19#ers and an m30 afm.
    Let me know.
    Thanks,
    E30Fiend
  • e30polak
    • 6136
    running rich eh? just share the wealth homey lol. j/k does ur chip have the proper fuel curve for the afm and injectors??? just my 2 cents...
    INSTAGRAM: @UNDR8D_EMPIRE
    • E30_fiend
      • Apr 2006
      • 7348
      Well I know for a fact that the chip isn't designed for it but I had been told this once before and that it was spittin out some shit when I shifted so this has been happening for a while.
      E30Fiend
      • e30polak
        • 6136
        since it seeems to be such a popular mod for the m20 then shouldn't there be a nice tune to adjust the timing, spark and fuel curve? maybe thicker guage ignition wires would help a lil?
        • E30_fiend
          • Apr 2006
          • 7348
          Taken care of. 8mm nology's. Bosch copper cores and an msd blaster 2.
          E30Fiend
          • e30polak
            • 6136
            well this is where i leave it to the big shots to explain it to u. sorry i tried ;)
            • E30_fiend
              • Apr 2006
              • 7348
              Well thanks anyway.
              I hope someone else can try to shed some light on this.
              Anyone?
              E30Fiend
              • E30_fiend
                • Apr 2006
                • 7348
                Come on, anyone?!?!
                Little help please.
                Thanks,
                E30Fiend
                  • 34844
                  it's because you're using a metering device calibrated for a different engine, and possibly your O2 sensor is dead. also, without a wideband readout there's no way to tell if you're actually running rich, or by how much.
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    thats actually what i was thinking also. hopefully I can pick up a new sensor within a couple weeks.
                    Do you think i can do anything else to check it? Like some sort of diagnostic??
                    thanks Nando,
                    E30Fiend
                    • lifeiskaos
                      • 1709
                      unplug the battery. it will reset your ECU and you should be good to go. it worked for me at least...
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        You think my car is winning rich because my ecu Is telling it to?
                        I guess its worth a shot.
                        Thanks,
                        E30Fiend
                        • pe2one
                          • Jan 2008
                          • 119
                          do you want to try out a diff chip?
                          Originally posted by E30_fiend
                          You have more E30s than people in your household.
                          E30Fiend
                          • E30_fiend
                            • Apr 2006
                            • 7348
                            I'm pretty sure its not the chip because it was doing it before I changed chips. I just wanna get a mark d chip cuz he makes chips for cars with the 19# injectors and the m30 air flow meter.
                            That would be nice.
                            E30Fiend
                            • eyagel
                              • Jan 2007
                              • 756
                              i vote 02, i have one ill shit out to u its used but whatever.
