After tuning the AFM wheel back to where it should have been, I decided to spend some time doing some work to the intake I have been meaning to get around to.
1) Drill the "motorsport" holes in the intake box. (I have a spare box from using the top for the M30 AFM swap, so why not?) Also known as the cheese grater mod.
2) Paint box/AFM - chipped paint off AFM, and the box was very dirty and light.
3) Put cleaner air filter in.
Before......gross.
Small holes at the top, where I started. The bigger dril bit was used when I got tired of ALL the small ones.
Drilled, the exterior side only. Not the front, bottom, nor back. Front too close to radiator, back to engine, bottom.....just didn't feel like it.
Aftermath.
Painted up. Yeah, so under is still pretty dirty. And the paint ran.....so what.
Installed.
Engine bay shot:
Review!
SOUNDS BADASS!
About the same as when I tried that big cone filter on the end of the M30 AFM. Not quite as loud, nor so as aggressive.....but also no sucking sound down low. I prefer it to the cone, and should help keep heat out of the intake just as well as heatshield. Great upgrade!
Before......gross.
Aftermath.
Installed.
Engine bay shot:
Review!
SOUNDS BADASS!
