Ricer Intake mod inspired by Porsche
  • mikeedler
    • 6707
    #91
    yeah to the rocket scientist^ I think this mod is not for the performance, but for the extra noise it makes. I actually got a ticket over here in germany and had to pay a fine for cutting the bottom of my air box off. pretty stupid!
    • Digitalwave
      is a poseur
      • 6302
      #92
      Originally posted by uofom3
      the stock airbox is designed with a purpose in mind... For example... considder the EVO vs Stock airbox on the e30 m3... BMW M realized how restricitive their small intake opening was, so they made the EVO which has a MUCH larger intake how, as well as has a "trumpet" that fits behind the radiator to cycle cool air to the airbox. By simply cutting holes in the side of the airbox, you are increasing the amount of air that can enter the airbox... BUT... with the AFM, a certain amount of air is alowed to enter the engine, so increasing VOLUME will not make a difference because of the resrtictive intake path. However, if you remove the AFM with something like A-n or an equivalent after market EMS... then "drilling holes" or, preferably, adding some other sort of intake setup with an individual TB setup would yield serious hp gains... but drilling holes only allows a higher volume of untuned, hot air to enter the intake path...
      It's for sound, not for gains... nobody really cares.
      RISING EDGE
      • rwh11385
        lance_entities
        • 18403
        #93
        I care! with drilled airbox it sounds FUUUUH RAZE! for no money!! yaaaay!
        • Rob
          • 8166
          #94
          Just for the record, I pulled the tube from the rear headlight cover to the airbox (same principle and sound FX as a drilled box) for a few dyno runs, and the motor ran really lean, almost dangerously so.....
          TIFWIW
          BEERTECH
          • ///M Powered
            • Jan 2004
            • 1109
            #95
            Yesterday i put a stock airbox bottom back in, as well as new hood insulation underneath, sounds much more quiet.
            • EverWiser
              • Aug 2004
              • 313
              #96
              Why is this thoroughly played out and useless thread still alive?
              • Rob
                • 8166
                #97
                because it might sound better, but it could potentially harm an engine...
                BEERTECH
                • Digitalwave
                  is a poseur
                  • 6302
                  #98
                  I don't see how it would harm it any more than a cone intake or M30 AFM.
                  RISING EDGE
                    • 34847
                    #99
                    it's probably the cheap ass gas you buy for your beater, Rob. ;)
                    • Rob
                      • 8166
                      #100
                      *shrug* they're your cars, enjoy.
                      nando- 100% 93 octane this go around :P
                      BEERTECH
                      • Digitalwave
                        is a poseur
                        • 6302
                        #101
                        I'm quite interested in hearing how this is going to hurt the car... please explain.
                        RISING EDGE
                        • erehemantresni
                          • 136
                          #102
                          its still being metered by the afm, so whats the big deal?
                          • Rob
                            • 8166
                            #103
                            TIFWIW
                            more info Here TJ....
                            BEERTECH
                            • trent
                              #104
                              TIFWIW
                              hahahahaha
                              • Jand3rson
                                • 37587
                                #105
                                That was awesome.
