Pull engine with tranny?
  • Digitalwave
    is a poseur
    • 6300
    How hard is it to pull an engine out with the auto tranny still attached? If it's possible, it seems like it'd be a ton easier than dropping the tranny first. All thats left of the engine is the block though, so balancing it on the engine hoist might be difficult with all the weight on the rear.
    RISING EDGE
  • Jordan
    • 12916
    Of course you can pull them as one unit... much easier to reinstall them that way too.
    FYI the block and bottom end in it is 2-3x heavier then the tranny.
    https://mtechniqueabs.com/
    • Digitalwave
      is a poseur
      • 6300
      Great, that saves a lot of work. Now to get everything dissconnected and ready to go.
      Didn't think the blocks were so heavy. I know auto trannies are quite heavy.
      RISING EDGE
      • e30evolution
        West Werks
        • 1888
        like 80-90 pounds if that
        http://www.westwerksauto.com
        • M-technik-3
          • 18946
          Cast iron weighs quite a bit.
          • Gus
            • Jan 2004
            • 285
            i was surprised at how light the 5spd tranny is....one person liftable...auto trannys are way heavier...one out of an old FWD of mine was twice and heavy and half as big as the getrag!
            JUNGL3
            1990 "333i" Sport
