Where does your temp needle sit?
  • LennysEleven
    • Mar 2004
    • 163
    I was wondering what the normal position for the temp needle is? Does anyone have a 325i and the needle never goes over half? Mine will go over when sitting but can sometimes go down to 1/4 if the heat is on and Im moving. Just wondering what the norm is.
    Also, what could cause my engine to have trouble revving past 5000 rpms?
    thanks
    Nick
  • e30Matt
    • 5077
    With the fan delete I still rarely see the temp needle sit at the middle mark. Driving around I sit just to the left of center with the aux fan off, and a little further left with it on. When I idle for long periods of time I cut the fan on anyway, so the needle will OCCASIONALLY creep up to the middle mark. Most stoplights aren't long enough for this to happen though.
    • jweb
      • 959
      Mine stays a good bit to the left of the middle. If i have the a/c on and I sit at a light for around one minute it will rise to the middle or a little above but it goes back down once I start driving again.
      Jamie Webster
      '89 325is - sold :(
      '96 Miata - sold
      '01 M5 - sold
      '02 Civic Si
      • drifty30
        • May 2004
        • 135
        after a new lower temp thermostat, mine's top temp is a needle width over 1/4 all the time. i also have an electric fan.
        • Erick
          Official R3V Drifter
          • 11169
          Mine stays on the 1/4 mark on the left if I'm in the highway and in between that and the middle if I'm on a stop and go basis.
          Only reached the 1/2 mark once after staying in the same spot in a traffic jam for 1/2 hour.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • BMW BMXER
            • 2325
            1/4.. runs cool.
            Sold it.
            • Kondour
              • 243
              halfway all day
              • parkerbink
                • Jun 2004
                • 10138
                Always slightly over 1/2 When my tire shreded (second one of the trip) while I waited for help with the ac on sitting in 158 degree noon heat in the Mexican desert it went to 3/4. Sat there for almost 2 hours, didn't go higher.
                btw how do you guys get the pictures to show up in your posts?
                • Kondour
                  • 243
                  using image tags. [img] where url goes [/img]
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Cool! Thanks!
                    • MikesJo
                      • Mar 2004
                      • 989
                      Needle width below half.
                      Vancouver Portrait Photographer
                      E30 M3 Wallpapers
                      • BS87
                        • 1606
                        Mine always sits right below or on the 1/2.. probably a combonation of the old engine and my driving habits..
                        • Jordan
                          • 12911
                          While moving it sits at 1/4
                          While sitting still idling, it will slowly creep up to 1/2
                          https://mtechniqueabs.com/
                          • SebSter
                            • May 2004
                            • 192
                            Mines the same as yours, but it should sit at halfway all the time even when moving. If it doesnt you are using more gas and I believe getting slightly less power too. Time to change the thermostat?
                            1990 325ix
                              • 34839
                              mine sits just a hair to the left of the middle. it used to sit at 1/4 before I replaced did the timing belt, waterpump, hoses, tstat and coolant.
