Separating drive shafts
  • Digitalwave
    is a poseur
    • 6283
    How is it done? To make the shipping size smaller, but also to replace the center support bearing on my new manual drive shaft.
    RISING EDGE
  • Jand3rson
    • 37587
    Re: Sepperating drive shafts
    This isn't to tell you how to do it, but make sure you know that once you separate it, you will have to take it to be rebalanced.
    • Digitalwave
      is a poseur
      • 6283
      So to replace the CSB the driveshaft must be rebalanced?
      RISING EDGE
      • Jand3rson
        • 37587
        Even if you just separate the driveshaft. But yes, it will have to be rebalanced after you install the new CSB.
        • Digitalwave
          is a poseur
          • 6283
          How much does that usually cost?
          RISING EDGE
          • Jand3rson
            • 37587
            Hmmm, I don't remember off hand, I will have to ask.
            • Digitalwave
              is a poseur
              • 6283
              I will ask the place that I get my flywheel lightened at if they can do it. Maybe give me a deal for both :) Thanks for the help Josh.
              RISING EDGE
              • Jand3rson
                • 37587
                Anytime. How come your sig appears sometimes and other times it doesn't?
                • Bill 84 318i
                  • 1600
                  Make sure you put the two pieces back together in the exact same way they were before (mark the splines with paint) and I wouldn't worry about rebalancing it.
                  See the big nut shaped thing that goes around it? Take a pipe wrench or channel locks or something and loosen that. Then they'll pull apart.
                  • Digitalwave
                    is a poseur
                    • 6283
                    I turn my sig off sometimes just so it doesn't appear over and over on the page.
                    Bill, that's a good idea, I will try that. If it wobbles when I reinstall it, its easy to remove to have it rebalanced.
                    RISING EDGE
                    • Jand3rson
                      • 37587
                      Wouldn't hurt though, escpecially if he can get it done for cheap enough. Maybe they'll give him a break since he's taking the flywheel there.
