Water Pump
  • Bhadole
    • 228
    Water Pump
    I was hearing what I thought sounded like a loose belt. So I took into the shop today, and they said if it was a belt, there would probably be a squealing noise as well (which there isn't). They diagnosed it as me needing a new water pump, which I am probably due for. I guess I just didn't realize they made that kind of noise when they wore out. Does this sound right to you guys? I don't want to blow $250 on something that wasn't the problem...
    Thanks.
  • Brew
    • 3060
    I can't tell you for sure that your problem is the water pump, but if it is, you're going to want to replace the timing belt and tensioner while your in there.
    '91 318is
    • Digitalwave
      is a poseur
      • 6292
      $250? A water pump is $35 from eap4parts.com
      RISING EDGE
      • Bhadole
        • 228
        thats what he quoted me at the shop...I've never done one myself, I'd probably screw it up. I could probably get a buddy to help me out though, if he's not busy.
        Let me worry about that though. All i want to know is if the water pump is likely the cause of the noise I am hearing.
        • modifiede30
          • 1208
          Don't blow $250. Do it yourself - it'll cost you like $50 for both the timing belt and water pump. Just buy a Bentley if you don't have one so you have a reference for the job.
          Driving is the only way to go faster....
          • ///M42 sport
            • 3952
            yeah, the cost of labor is what empties your wallet the fastest.
            ________
            RedMiledy
            • demlotcrew
              • May 2004
              • 297
              do you need to change the Timing belt if you take the water pump out?
              Anyway you know when the water pump is gone as it leaks alot of water.
              Andrew AT E30zone.co.uk | H23-is | S14
              • Werksmini
                • 1658
                Yea im pretty sure if you take the tension off the belt you will need to get a new one. There not expensive anyways, its cheap insurance.
                I bombed Korea every night.
                • AdamF 88iS
                  • 2051
                  Timing belts are absolutly one time use.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
                  • BS87
                    • 1606
                    Last time i saw someone re-use a Timing belt, They got about 1 hour down the road before it went kaboom.
                    • demlotcrew
                      • May 2004
                      • 297
                      Is the pump driven by the Timing belt? im sure its not! well its not on the M40/M42 and im sure its not on the M20
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        Ohhh yes it is.
                        • Sean
                          • 5793
                          If you're going to replace that water pump, just replace the timing belt too. Chances are, it already needs to be replaced, sinec usualy the water pump and timing belt need replacement at the same time.
                          That, and why not do it? If you're doing all that labor, might as well do it only once, rather than twice.
                          - Sean Hayes
