Changing airfilter
  • parkerbink
    • Jun 2004
    • 10138
    Changing airfilter
    My Haynes manual shows a completely different airbox & procedure for opening it. What do I have to do to get into this airbox?
    Thanks
  • Erick
    Official R3V Drifter
    • 11169
    Dude it ain't rocket science, I looked at my engine bay and replaced it without questioning anything.
    I like space to work, so I just removed the AFM and the airbox from the car. After that, take off the 4 clips holding the airbox together and put the new filter in.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • parkerbink
      • Jun 2004
      • 10138
      Thanks but dude it ain't necessary to be a dick.
      • e30Matt
        • 5077
        If you don't want help don't ask. Changing the air filter is one of the most simple maintenance tasks on a car to perform, short of checking the air in the tires.
        • parkerbink
          • Jun 2004
          • 10138
          There appear to be several fastners that may or may not need to be removed. I don't wan t to do more than I have to, so I asked. It is unnecessary to make rude comments like it ain't rocket science. If you don't want to help don't reply
          • e30Matt
            • 5077
            When all else fails, just remove the whole thing and pull it apart or buy a Bentley manual. Sometimes the best way to figure it out is to take it apart and put it back together.
            There are 4 clips holding the bottom half of the airbox on. Unbolt it from the support bracket, flex it up and remove the clips, then remove the bottom half of the airbox w/the filter, swap the filter and reverse the steps to put it back together.
            • aaron_silva
              • 1785
              You would have had it done by now if you figured it out yourself.
              Good luck!
              Aaron
              • parkerbink
                • Jun 2004
                • 10138
                I am planning on doing it in the morning. I have a new oem filter but want to know how to do it so I can do it in Laredo in the hotel parking lot after I get the K&N. I have a Haynes manual that must be showing an early car it is totally different.
                I have r&r'd engines using only the manual & intuition, but I know there are always tricks to doing anything so I asked. I see no reason that I shouldn't ask including the possibility I will get unpleasant responses. Thanks for the help.
                My Tundra's was easy to remove 4 clips top off pull filter replace filter replace 4 clips.
                • James Crivellone
                  Head Janitor
                  • 6305
                  all e30's had the same damn airbox configuration, at least the M20 Carz
                  • Erick
                    • 11169
                    Ok, you need a 10mm and a 13mm wrench/socket.
                    Take off the 2 nuts holding the airbox on the driver's side and another nut holding the AFM in place. With a screwdriver, unscrew the intake boot a bit to disconnect the AFM from it. Pull AFM and airbox in upwards direction ( that means up and out of the hood ).
                    There are 4 clips holding the top portion of the airbox to the bottom part of the airbox. Unclip them by putting your hand in the clips and pulling them off the top part of the airbox. WARNING: bottom part may fall when unfastening the last clip.
                    Look for the old air filter and replace it with the new one. Re-installing is just the opposite of what I said. That means do the last step first, onwards until you get to the first step last.
                    For future reference, buy a Bentley.
                    Feedback Thread
                    • Digitalwave
                      is a poseur
                      • 6299
                      RISING EDGE
                      • F|2eeSTy|e
                        • 372
                        I dont get it :oops:
                        Brandon
                        • parkerbink
                          • Jun 2004
                          • 10138
                          Thank you very much, should you want to refer the original post I have a Haynes and it looks completelty different so I asked, further I don't trust it because everything I have tried to use it for has been completely different than it has shown. Thats why I bought a dvd manual that is supposed to have everything from e30 to current, that should keep me from asking any more tecnical questions, but it's in Laredo so I have to ask until next week.
                          • parkerbink
                            • Jun 2004
                            • 10138
                            Done, was easy & all is well.
                            Thanks
                            • Charlie
                              kid tested, administrator approved
                              • 6686
                              Take it to a dealer.
                              -Charlie
                              Swing wild, brake later, don't apologize.
                              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                              FYYFF
