removing and cleaning ICV valve
  • Court M3
    • Jan 2004
    • 6713
    anyone got instructions or how to? Tach jumps to 2k when car is started up and stays there until car is put in gear.
    Continuous For Sale Thread
    323i s50
  • Jand3rson
    • 37587
    You need to get an ELECTRONICS FRIENDLY spray cleaner. I can't stress enough how important it is that you get the right kind, you will kill your ICV otherwise.
    • LikeCDoos
      • Jan 2004
      • 2522
      what are the symptoms of a dead ICV? I cleaned mine with carb cleaner :oops:
        • 34844
        I cleaned mine with carb cleaner too.. it was pretty clean to start with though, so it made no difference to my idle. :(
        • kencopperwheat
          King of Kegstands
          • 14396
          I cleaned mine with carb cleaner once... it still works fine. Now I use electronics cleaner.
          Originally posted by Gruelius
          • Fanzotti
            • 1255
            Anyone got some info/steps on doing this? Gotta clean mine tomorrow.
            Everybody says to use carb cleaner. Is electronics cleaner still believed to be neccesary or can you use carb cleaner? If so can you give the name of the electronics cleaner to be used?
            Thanks dudes.
            • MoparJ
              • May 2007
              • 258
              I asked this question a long time ago over on 190revolution regarding the ICV on my girlfriend's 190e; they said carb cleaner is fine as long as you hold it with the electrical connector side up while you are cleaning it. Electrical cleaner would work, too.
              Jason
              • AL GReeNeRy
                • 136
                try using intake/maf sensor cleaner. your local auto parts house should have it. if its safe enough for a mass air sensor it should be safe enough for an icv
                1991 318is nv m50 : brilliantrot
                • Fanzotti
                  • 1255
                  Thanks dudes! Any name for this electrical cleaner and where to get it? So it seems carb cleaner will also work?
                  • Fanzotti
                    • 1255
                    Found electric parts cleaner at Pep Boys.
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      MAF/AFM cleaner is probably your best bet, it's at most auto parts stores.
                      • MoparJ
                        • May 2007
                        • 258
                        We sell the MAF cleaner at my work (Kragen); it's made by CRC.
                        Jason
                        • optimusp517
                          • Oct 2005
                          • 797
                          You should be able to find electric parts cleaner at any auto stores. My symptom that I had when my ICV went out was bogging. Sometimes I'd get random bogging of my car and it felt scary cause seems like your car was ready to die at any moment and it goes away right away, but it did that on a regular basis until I found out what it was.
