valve adjustment: aftermath
  • bmwannabe
    • 900
    how will i know if i did it right, so far i havent noticed any difference? how long will it take my car to blow up if i did it wrong?
  • kencopperwheat
    King of Kegstands
    • 14396
    You didn't notice that the valves are quieter?
    Originally posted by Gruelius
    • Kavkazia
      • 394
      It will not blow up, the rocker arm will snap, if it's too tight!
      95' M3.
      90' 325i Turboed.
      87' 325eS Fixed.
      • ///M42 sport
        • 3952
        off topic but will your rocker arm snap if you redline the m20 alot?
        ________
        Lovely Wendie
        • E30godz
          • 1524
          i bet i have lots of broken rockers then...
            • 34844
            only if you're bouncing off the rev limiter constantly. going to the redline won't hurt anything. I bounced off the 6900rpm rev limit on accident with my other chip, nothing bad happened. just don't make a habit out of it.
            generally, going past 6k is a waste of time anyway, the M20 doesn't make much power up there. I usually shift (or let the tranny shift) at about 6k if I'm trying to get somewhere.
            • Jand3rson
              • 37587
              Did you adjust the valves to the correct measurement using a feeler gauge? Then you did it right.
              • SlammedE30
                • 741
                My car has seen 6900 MANY times. many many many times It's fine.
                -Ted
                • bmwannabe
                  • 900
                  yeah, they are a small bit quieter, i started doing it when the engine was warm, then it cooled off a little bit, so i dont know if the metal went from expanded, then back to normal size while i was still using the reccomended feeler guage size for when the engine was hot, which i beleive was .300 mm
