Koni Adj. in front and Bilstein Sport in rear?
  • kencopperwheat
    King of Kegstands
    • 14396
    I've been thinking about getting some Koni Adjustables for my front struts and some Bilstein sports for the rears. Does this sound like a good set-up?
    Where is the best place to get the Konis?
    Originally posted by Gruelius
    • 34839
    go with konis or bilstiens all around IMO.. why only have adjustability on the front?
    also if you have soft springs it could mess up your ride, konis on their high setting are a lot stiffer than bilstiens..
    • Bryson
      • 1490
      no. If you were to go mismatched I would do it the other way around. The rear bilsteins just aren't enough for me without different valving
      • M-technik-3
        • 18946
        That is the way my car is set up right now stiff Koni's rear Bilstein Sports in front.
        • kencopperwheat
          King of Kegstands
          • 14396
          Wouldn't it be best to control nose-dive in the front?
          • M-technik-3
            • 18946
            You can control it with spring rates. Mine were temporary fit due to I was having my SA converted to DA. I have them back but I just have gotten the time to install them yet.
            • Digitalwave
              is a poseur
              • 6299
              They don't make 45mm Bilstein Sport fronts do they? I would say that the Sports would be plenty stiff for your cheap-o springs, but if they don't make Sports for the front, get Konis all around and run them soft.
              RISING EDGE
              • M-technik-3
                • 18946
                Yes they do, for the older 85 318i I got a set from Josh and my car was 51mm so I sold them to CourtM3. They have traveled the world twice.
                • Digitalwave
                  is a poseur
                  • 6299
                  That's cool, I wasn't sure on that. I guess they don't make them for iX's, and that is what I was thinking.
                  RISING EDGE
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    I would say that the Sports would be plenty stiff for your cheap-o springs.
                    Good Point. I'll get the sports and save some $ in the process.
