Finishing up stuff... need help!
  • Digitalwave
    is a poseur
    • 6299
    Alright, so I am in the final stages of my conversion.
    First off, the pedal assembly. Does that big clutch spring just slide into place on that notched bracket as pictured? And is the clutch pedal supposed to sit so far away from the red switch? The pedal seems to be in the right place, as it sits at the same level as the brake pedal does, maybe the bracket is just bent.
    And when I push the clutch pedal in, the spring pivots and the pedal doesn't return. I figure this is because the master cylinder is not pressurized - is this correct?
    On the starter motor, does the positive (red) lead go on the left side or the right (looking from the front of the car). I can't figure that one out. This picture is obviously taken from the driver's side fender. As you can see I have the red wire resting on the left side, but before I install the nuts I want to make sure.
    RISING EDGE
  • mspiegle
    • 1026
    with my 928, if i have no pressure in the clutch cylinder, the pedal will flop to the floor and never return back. I assume its that way on other 5spd cars.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
    • e30Matt
      • 5077
      That's what happened when the master cylinder went in my 325. Sucked to the floor, I had to drive it home clutchless, except for starts and stops.
      • RCWells
        • 3589
        TJ, went and looked at mine and both the big black wire AND the red go to the right side if looking from the front of the car. Don't know why. There is a third smaller black wire that goes to the left post. Hope this helps. The big black one went on the bottom and the red one overlaid it on my starter.
        [THE 501 club - Founding Member]
        • Digitalwave
          is a poseur
          • 6299
          That's weird. There are 4 posts and 4 wires. 2 black small ones, 1 black big one, and 1 red big one. There are 2 small posts on the top and the bottom, I attached the small wires to those. I am really confused now.
          RISING EDGE
          • Digitalwave
            is a poseur
            • 6299
            Someone please help, the starter is the last thing I have to do.
            RISING EDGE
            • DanGillan
              • Mar 2004
              • 4061
              haha, you posted at 8am. anyone that's not sleeping is at work, give it some time. You must be anxious to get that thing running though hu? is EVERYTHING! else done? that's sick, definately cant wait to see your car a manual. Ill see what I can find to help you out, give me a little while, im at work.
              Dan
              • Beej '86 325es
                • 2639
                I really don't know what the point of that spring is. Mine randomly broke and fell out over a year ago. I can't even tell the difference.
                -Brandon
                '86 325es S50
                '12 VW GTI Autobahn DSG
                '03 540i M-Sport (sold)
                '08 Jeep SRT-8 (sold)
                For sale:
                S50 TMS chip for Schricks
                • rs4pro3
                  • 5808
                  TJ On the starter both the Large Black Wire and the Large guage red wire from the Engine harness go to that same right side post. The small black wire coming off the starter goes to the Post that is under neath and to the left of that large post, it has a smaller nut on it.
                  85 325e 2.7 ITB'd stroker
                  • Digitalwave
                    is a poseur
                    • 6299
                    Ely, so the right post as in right if you are looking from the front of the car? I got it then, I appreciate it buddy.
                    RISING EDGE
                    • DanGillan
                      • Mar 2004
                      • 4061
                      so we might have blast off in a few minutes? :twisted: let us know how it goes
                      Dan
                      • rs4pro3
                        • 5808
                        Yep Right as in Right from front, I just got a 325i starter in the mail last night so I verified the wiring. a lot of cars have a spade conector for that smaller black connector which makes it easier to find where it goes but 88 and newer got the Bolt down.
                        • Digitalwave
                          is a poseur
                          • 6299
                          Eh, still got to put the exhaust on and bleed the brakes :)
                          RISING EDGE
                          • DanGillan
                            • Mar 2004
                            • 4061
                            damn, get cracking :)
                            Dan
                            • Mystikal
                              Wheel Fitment Expert
                              • 9602
                              Get cracking? I don't think I've ever seen someone attack a project so big so quickly. :shock:
