What to use to Recharge NiCad Batteries?
  • LikeCDoos
    • Jan 2004
    • 2522
    I just bought 2 Nickel-Cadmium AA batteries from Radio Shack (PN: 23-191) to replace my SI batteries and I need to get a full charge in them before i solder then onto the board. I was thinking of using my optical mouse recharger but that takes Nickel Metal Hydride batteries. I need some other options on charging these batteries other than going out and spending $40 for a charger. Anything helps...
  • kencopperwheat
    King of Kegstands
    • 14396
    The NiMH charger won't charge NiCads.
    Originally posted by Gruelius
    • rs4pro3
      • 5808
      Look at Walmart or the drug store for a charger. They make chargers you can put 4 AA batteries in and just plug them in the wall. I've got a Rayovac Charger I use.
      85 325e 2.7 ITB'd stroker
      • kylebes1
        • May 2004
        • 2804
        I replaced mine and did not read that they had to be charged first. Well the SI board has yet to start working and my Speedo seems to be affected by this. After a few minutes of driving the speedo usually starts working
        • LikeCDoos
          • Jan 2004
          • 2522
          Ya your suppose to recharge the batteries before you put them in, as i understand it they are basically dead until you give them a full recharge. Ya i know the NiMH charger won't charge the NiCad's.
          I was thinking of buying a charger...using it then returning it.
          • kylebes1
            • May 2004
            • 2804
            I know that now, but they are already sodiered to the board so I guess since I have three more boards I will try again
            • e30Matt
              • 5077
              Or just desolder 'em and charge them. Don't be lazy. :P
              • kylebes1
                • May 2004
                • 2804
                not to much heat?
                • kylebes1
                  • May 2004
                  • 2804
                  Is the SI board independant of the ECU? I have the m50tu now so will that affect it>?
                  • Ryan Stewart
                    I Love Miatas
                    • 8978
                    given the wiring diagrams I have been given the engine has no clue what the SI board is doing.
                    Im now E30less.
                    • kylebes1
                      • May 2004
                      • 2804
                      is there any way to lose the SI board?
                      • reelizmpro
                        • 9558
                        The board will recharge the batteries over time. I have sucessfully replaced batteries back in the day without charging them.
                        88 M3 - LACHSSILBER
                        89 M3 - ALPINEWEISS II
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          so after time the car will recharge the batteries on there own? hum...that would be alot easier than buying a charger
                          • Z3Jonathan
                            • 289
                            Re: What to use to Recharge NiCad Batteries?
                            You can buy off-the-shelf NiCAD battery chargers for ~$20. I got one from Best Buy to recharge my digicam batteries.
                            • Mystikal
                              Wheel Fitment Expert
                              • 9602
                              Bingo.
