Speedometer trouble
  • kylebes1
    • May 2004
    • 2804
    Speedometer trouble
    One day my speedometer just stopped working. I replaced it with a used part.
    Well now it works but only if it wants to, there is no variable that makes it work or not work it is completely crazy!
    Sometimes after driving a few mile it begins to bounce up, like five or six times, then it works until I have ot shut the car off again. Aftre this it usually goes back to sleep and does not work again for a while.
    I want to get this thing working again so I now if I am speeding or not!
    I cannot afford another ticket!
    • 34827
    check the sensor on your diff, the wires get brittle and can break. also make sure your speedo is grounded properly.
    • kylebes1
      • May 2004
      • 2804
      I just chaged diffs, but I will check the actually wires. Is there a common ground for the cluster? where does the speedo ground?
      • kylebes1
        • May 2004
        • 2804
        checked all the conectors and wires, everything is A1. need more options
        • Jarvis
          • 2132
          Re: Speedometer trouble
          Anyone who has driven the same car for more than a week should be able to figure out MPH based on which gear they're in and RPMs. My speedometer hasn't worked since December, but I still always know how fast I'm going to within 2 MPH or so.
          • Digitalwave
            is a poseur
            • 6282
            Are you sure the new speedo you got was good? The gears strip in them all the time, and it will cause the problems you are having.
            RISING EDGE
            • kylebes1
              • May 2004
              • 2804
              All my gearing is different now with the m50. I do not like to explain myself in such ways.
              I picke d it up used and have since ordered another one form a guy on here, it also is used, he only wanted 10 bucks for it, so if this does not work i am buying a new cluster and speedo and the other gauges as well form the dealer.
              • Digitalwave
                is a poseur
                • 6282
                Ouch, I wouldn't like to see the bill for a new cluster and gauges from the dealer.
                RISING EDGE
                • kylebes1
                  • May 2004
                  • 2804
                  the speedo alone is 350.00 but that is a last resort
                  • Halon
                    • Jun 2004
                    • 50
                    dizamn. I can't afford 350. Mine is broken too. Damn Cheap-ass BMWs! :P Haha. kidding. Seriously, for such a nice car though, my car has alot of ghetto in it. Maybe someone left it parked next to a a '68 impalla too long or something.
