is there any way to test a water pump
  • trashcop 80s 80s
    • Jun 2004
    • 1130
    This might be a dumb question but I have searched and I can't find any info on it. Is there any way to test a water pump on an 89 325i without having to remove it? The car is overheating, I've already replaced the thermostat and that didn't help.
  • Axxe
    • Aug 2004
    • 3355
    Does it overheat on the highway?
    Keep it slideways!!
    • AdamF 88iS
      • 2051
      Theres nothing to test, really. Does it leak?
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • trashcop 80s 80s
        • Jun 2004
        • 1130
        I don't know if its overheating on the highway because the temp guage isn't working. Is there no way to see if it is even pumping coolant through the engine?
        • ///M42 sport
          • 3952
          how do you know its overheating then?
          • m42technic
            • 1056
            The million dollar question.
            James Peacock
            WWFSMD?
            • trashcop 80s 80s
              • Jun 2004
              • 1130
              Because water starts boiling out of the coolant reservoir and steam starts coming out.
              • M-technik-3
                • 18946
                Hello warped cylinder head....
                • brodee
                  • Jan 2004
                  • 2914
                  I doubt there is a problem with the water pump if you are boiing over in the resevoir. If the pump wasn't working at all then there would cold water in the radiator and all the hot water would stay in the engine and not be pumped out.
                  Sounds to me like you have another issue. If the temp guage isn't working then GET it working before you start the car again. Also check your oil first and make sure it's not milky.
                  "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                  1988 M3 - Track Rat
                  1989 325iC M50 Vert
                  1989 325i Coupe
                  1991 318is
                  1995 318ti Club Sport
                  2006 330i e90
                  2008 Tundra Crewmax
                  • trashcop 80s 80s
                    • Jun 2004
                    • 1130
                    I think the temp sender needs to be rewired because I swapped in a cluster that had a good guage and it didn't work. I also tried a working temp sender and nothing happened. Then I tried grounding the plug for the temp sender and the guage still didn't move.
                    • trashcop 80s 80s
                      • Jun 2004
                      • 1130
                      The oil is not milky, so no blown headgasket. What else would be causing it to overheat??
                      • Digitalwave
                        is a poseur
                        • 6300
                        Your headgasket can very well be blown and not have milky oil.
                        RISING EDGE
                        • EverWiser
                          • Aug 2004
                          • 313
                          Just because the oil is not milky doesn't mean you don't have a blown head gasket. It just means that the "blown" part of the gasket is not allowing the oil and water to mix. You could still have a water leak between one or more cylinders and be pressurizing/boilling the water in the combustion chamber causing it to overpressure your cooling system. However, you should be able to see massive amounts of white smoke out of your exhaust if this is the case.
                          You also might have air in the system and your pump won't be able to move the water properly. My girlfriends '89 525i with the M20B25 engine did this. Once I filled the engine with water (I filled it through the T-stat housing) and bled the air out of the system, everything was fine. Also, you might as well change the T-stat while you're working on everything. It could be opening late which can cause the problem you describe. Just my .02...
                          • trashcop 80s 80s
                            • Jun 2004
                            • 1130
                            Thanks for the info. I'll go try bleeding the system.
                            • hotghias
                              • Jan 2004
                              • 148
                              i recently replaced the thermostat in my eta because the car was overheating. when i dropped the old one in hot water with the new one, the new one opened much sooner. i had thought that failed thermostats only stuck open (and caused cool running) when they failed, but they can do both. the new thermostat definitely fixed the problem.
