Clutch squish; Removing air
  • xLibelle
    • Aug 2004
    • 2673
    I replaced my slave cylinder because of a hole in the seal, not sure how that happened.
    Bled the system and clutch works great. But there's still some air (it seems) thats trapped in the top of the master cylinder. I've done some rapid clutch pumps two days, five minutes each day, which has improved the problem but theres still about 1-2 inches of clutch travel at the top before it activates the clutch.
    Is this normal? Is it air? How do you FULLY bleed the system?
  • xLibelle
    • Aug 2004
    • 2673
    does anyone at least have a description of their own clutch pedal feel?
    • lordofthewaters
      • Oct 2005
      • 714
      What i do to bleed, is pump fully once, then push till just past initial resistance say 20 times, then repeat several times. All with the reservoir cap off. Usually works.
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • netcsk
        • Apr 2004
        • 1609
        The best way I have found to get it bled is to remove the cap on the reservoir, remove the slave cylinder from the transmission; then push and release the rod on the slave cylinder with your hand a few times slowly. This has always worked for me.
        You should only have a maximum of an inch or two that doesn't have resistance.
        • xLibelle
          • Aug 2004
          • 2673
          Is everyone finding this to be the same and true?
          • DRTSRFR
            • May 2008
            • 1836
            I just finished replacing my clutch, master, and slave and have the same issue.
            The clutch works fine, but the pedal doesnt come back to the safety switch. It's about an inch lower than it was previously. I adjusted the pedal cam with little success.
            Suspension tips here...
            http://www.r3vlimited.com/board/album.php?albumid=757
            • xLibelle
              • Aug 2004
              • 2673
              the issue you speak about is not what my question is regarding.
              Your clutch not coming all the way out could be the need to set the return spring to the right place. I dont know what the pedal cam is.
              If there is resistance when you pull the clutch pedal to the switch, there may be other problems you have. You would want to open a different thread regarding that.
              • DRTSRFR
                • May 2008
                • 1836
                Sorry, my bad:???:
                • netcsk
                  • Apr 2004
                  • 1609
                  You need to look at the spring that attaches to your clutch pedal arm. It likely is not in the "notch" that it is supposed to ride in, so the pedal isn't being helped by this spring.
                  • supraru
                    • 31
                    I just bled my clutch last night after replacing the master. Had a hard time bleeding to start with using conventional method, then wound up opening the bleeder fully, filling the reservoir, and pumping slowly on the pedal. I had about three large bubbles of air per pump come out of the reservoir, with cap off. After a minute of that I closed the bleeder, did the same thing for the next three minutes and all of my pedal came right back, only cracked the bleeder one more time to make sure it was all fluid coming out, which it was.
                    Hope something in there might help you. my pedal has about 1 inch of travel before disengaging, maybe a little more, like others above suggested.
                    • DRTSRFR
                      • May 2008
                      • 1836
                      You were absolutely correct!
                      Thanks.
                        • 34847
                        pressure bleeder.. replaced my MC on friday, bled all the brakes + clutch in about 15 minutes.
                        • xLibelle
                          • Aug 2004
                          • 2673
                          DRTSRFR, if you read my statement, youd have had it fixed a lot sooner. Sorry if it was vague.
                          Nando, it appears i need to get one of those... I have found myself doing more brake jobs and clutch jobs than i anticipated.
                          I have also found that it helps to remove all the air when servicing the clutch with the nose of the car DOWN. If its up, there will be air trapped in the high point of the slave.
                          • accident
                            • 7303
                            pressure bleed ftw
                            Moral of this story?
