Bunch of questions...exhaust, valves, suspension
  • clutterbucker
    • Jun 2004
    • 481
    1. Suspension: I just recently ordered and had installed Bilstein Sports, H&R springs, Susp. Tech. Sways, and new mountas and reinforcements up the azz. The car handles amazingly, but when I picked it up , I only pushed down on the hood to feel the difference. Today, I pushed down on the trunk...and it was very noticeably less firm than the front. Is this normal?
    2. Valves: My idles sounds like crap, tach says it's ok, and is a little shaky on startup and at normal idle. Valve adjustement fix?
    3. Exhaust: (I was thinking this could be part of the shaky idle and nasty idle sounds) I need a new exhaust. I have a new muffler, but I need everything from the motor back, and would like a resonator in there this time. Where can I go to get a brand new motor-back exhaust with a resonator...what are my most cost-effective options? Custom?
    Thansk in advance for any replies!
    - 2000 Audi S4 Stg 2 (sold)
    - house (bought)
    - 1997 Civic Hatch (shaky but driveable)
    - 2010 Sportster 1200 Forty Eight Ed. (vroom)
    - 1991 318is S50B30 (TBA)
    • 34847
    a rough idle (with a steady tach) has nothing to do with the valves... but it could be many things, vacuum leak, FPR, fuel filters, injectors, plug wires.. I have the same "problem" and haven't managed to nail it down yet, although by fixing my vacuum leaks and doing some basic tune up work I've managed to tone it down quite a bit. I'm planning a fairly major tune up in the next few weeks so hopefully I can finally get rid of that issue.
    • clutterbucker
      • Jun 2004
      • 481
      thanks nando,
      anyone have any ideas about my uneven suspension or where i can get a full exhaust for a decent price?
      - house (bought)
      • BahnE30
        • 1050
        what springs / shocks are you running
        that would help us :?
        • clutterbucker
          • Jun 2004
          • 481
          I'm sorry I thought I said what they were...*EDIT: I did say what suspension I was running....just so ya know.*
          Bilstein Sport Shocks and H&R Springs.
          I distinctly remember my old E36's suspension being setup about the same way but I don't really trust the know-how of the mechanics I brought the car to this time...and was just checking.
          Thanks
          - house (bought)
          • elemental
            • Jan 2004
            • 112
            Well H&R has a few diffent lines i have had the Race and yes the back end of the car is softer than the front i have IE 3 springs on my e30 and the front is way more firm than the rear
            Thanks
            • clutterbucker
              • Jun 2004
              • 481
              Thanks man, I figured it was ok, but couldn't be sure. No one in Buffalo knows anything about E30's, so I'm all alone here....except for one kid (that I know of).
              - house (bought)
              • clutterbucker
                • Jun 2004
                • 481
                I guess I'll have to adjust the valves then soon. There's also a hesitation....like when I punch the gas, there's a slight delay before the motor fevs....sort of like it's choking for a second. Will the valve adjustment take care of that you think?
                - house (bought)
                • Digitalwave
                  is a poseur
                  • 6300
                  No.
                  RISING EDGE
                  • Jand3rson
                    • 37587
                    No.
                    How about giving him an answer WHY along with the no, TJ? And maybe explain to him what could fix it?
                    I don't know what it is about you lately, but your replies in almost every post are getting more sarcastic and less helpful.
                    • James Crivellone
                      Head Janitor
                      • 6305
                      you expect an AFM/Motronic Equipped motor to rev the second you blip the butterfly?
                      aint gunna happen
                      • UNHCLL
                        • 8790
                        is this with the m30 afm i sent you or is this still with the original one??
                        There is always a hesitation on AFM'd cars....
                        He's so busy playing with his new knob, there's no time for stephanie to enjoy it... err ummm waiiit a second...... 8)
                        Below the radar...
                        • clutterbucker
                          • Jun 2004
                          • 481
                          no, it isn't with the M30 AFM. I still can't figure out how to swap the electronics...havent had enough time to sit down with it and figure it out.
                          Sorry about the delayed post....I've been working like a maniac. So there's always a hesitation after you hit the gas pedal?? I thought maybe something was wrong, so I ordered a bunch of replacement parts (O2 sensor, fuel filter, fuel pump, injectors soon) just to make sure. Ah well, it can't hurt. Why is it that there is such a hesitation. Can I do an ECU upgrade?
                          - house (bought)
                            • 34847
                            an ECU "upgrade" won't do anything. all Motronic 1.3 ECUs are pretty much the same.
                            replacing all those parts might help though (fuel pump and filters is one thing I haven't done yet).
                            • clutterbucker
                              • Jun 2004
                              • 481
                              alright, you guys seem to know aq lot, and I don't wantr to start a new thread and get yelled at.....
                              So how much would a used M50 motor & tranny with everything needed along with installation cost me.....roughly.
                              - house (bought)
