Strange idle noise
  • dwforum
    • 220
    Strange idle noise
    Every once in a while, when my car idles for too long, a few minutes at least, the engine compartment starts to make a funny noise. It's hard to describe, but it sounds like something is trying to spin but is being resisted, but it has no affect on the way the car drives. Either turning the car off for a few minutes or driving the car at higher revs for a few minutes gets rid of the noise. I'll try and come up with a better way to describe the noise, but does anyone have any ideas what it might be? Thanks
  • Digitalwave
    is a poseur
    • 6293
    Have you checked the fans and belts in the engine bay?
    RISING EDGE
    • Rosica
      • Jan 2004
      • 240
      Does it sound like a rattle, does it go away when you push in the clutch?
      07 335xi Sport
      00 S2k
      01 A4 1.8t-Sold
      88 M3-Sold
      91 325iC-Totaled
      89 325iS - Sold
      87 325-Totaled
      • KDZROK
        • Aug 2004
        • 759
        Mine does this, what is it???
        • BE30s
          • 85
          your throwout bearing if i have that spelled right.
          • dwforum
            • 220
            Mine isn't a rattle sound, I guess the best way to describe it is a very low squeaking or rubbing sound. I think it is possible a belt or something is rubbing, but I am not sure how I would go about checking.
            • LikeCDoos
              • Jan 2004
              • 2522
              my throw out bearing does this as well, is it anything to be too worried about or should i just replace it when i do my clutch?
              • sovann
                • Jan 2004
                • 292
                I believe it's actually play in the gearbox - I've read that the Getrag gearboxes have relatively loose tolerances so produce a bit of noise.
                Mine does it as well. Replaced the clutch and throwout bearing etc. and the sound is still there.
