noise from fresh clutch
  • Chris E30 Cab
    • 866
    I recently had a new clutch installed but when the gearbox is in neutral and the clutch pedal is up there is a rattling noise coming from the clutch/flywheel. Any idea what this could be? This wasn't the case before the recent engine rebuild & flywheel resurfacing.
    Thanks!
  • lifeiskaos
    • 1709
    i have the same problem
    • SamE30e
      • Sep 2007
      • 4319
      Me too. It's quite annoying.
      1985 325e 2.8 Turbo VEMS
      • akorcovelos
        • Dec 2006
        • 1149
        sounds like your TO bearing may have been installed wrong. I would say it's warn out, but if the whole clutch package is new I would go with poorly installed.
        2012 MCSCC/NSSCC CP class champ
        HSAX Instructor
        • ColdAccord
          • 5926
          Tob
          Originally posted by blunt
          • GotCone?
            • Jan 2008
            • 589
            Originally posted by ColdAccord
            Tob
            agreed
            Build : Das Drehmoment Ungeheuer
              A mild rattle in neutral with the clutch engaged, that disappears when you depress the clutch pedal, is probably from the transmission input shaft and is nothing to be concerned about. The cause can be from wear in the input shaft, but even perfect input shaft bearings will rattle if a lightweight flywheel is fitted.
                • 34847
                yeah, it's pretty common on getrag transmissions. I saw this porsche at an autox once and his transmission was making the same rattle noise mine does at idle, I asked him if it had a getrag and he confirmed. "getrag rattle" is the term for it.
                it may be that the lighter weight of the resurfaced flywheel has contributed some. it *could* be the TOB, but if it's working fine I would just leave it, unless you enjoy dropping the transmission.
                • Chris E30 Cab
                  • 866
                  cheers fellas, a new TOB was used so onto worrying about other things ;)
                  • NC325iC
                    • Mar 2004
                    • 6565
                    this problem pisses me off so much, mine is pretty loud and very annoying
                      • 37833
                      My S50 car didn't make the Getrag noise, until I put my cams in. Now with the rough lopey idle it does it sometimes and I hate it. The B25 325e doesn't make his noise, thank god.
                      Grover Beach, California
                      BimmerHeads.com
                      • Nicademus
                        • 2912
                        I've got the same problem. The car rattles when its in neutral and then when the clutch is pressed in the noise goes away.
                        Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
                        ~ John Adams ~
                        • Jesse30
                          • Jan 2007
                          • 3936
                          my car does the same thing. turn your music up louder or get a louder exhaust. problem fixed :D
                          • Van Westervelt
                            • 9365
                            Try an 8lb flywheel on a cam'd s50 and a g260 with 260k on it. It rattles a tad :)
                            Woohoo for a fresh trans goin in this winter.
                            • James Crivellone
                              Head Janitor
                              • 6305
                              mine sounds like a jar of marbles fucking exploded inside the bellhousing at idle...I'm SURE my lopey idle REALLY helps this too :p
