noise from fresh clutch
  • JAM
    • Feb 2007
    • 524
    my car does this too
    actually, BOTH of my cars do this but not nearly as loudly as you described. i always just assumed it was normal
    Originally posted by Mr Watsonsilver
    driving boards?
    • lifeiskaos
      • 1709
      so does anyone know the actual problem?
        • 34844
        getrags can be noisy at idle with a lightweight flywheel. there isn't anything "broken", although supposedly replacing the input shaft bearings helps. If I'm not mistaken though, james replaced all of that stuff and his still rattles. That must have pissed him off. :p
        • James Crivellone
          Head Janitor
          • 6305
          Yep, new shift fork, input shaft bearing, new clutch, new TO bearing, new pressure plate, new slave cylinder, everything.
          I give up, my fix is a Getrag 280
          • Jparkr
            HR Admin
            • Jan 2006
            • 3494
            oh man. My old shop replaced the input bearing for James. My boss Pete and I finally found the correct puller tool and everything and it took us a little time to find it. We used a BMW bearing, not an AM OEM one. Once we were done Pete and I celebrated. Until James and I installed his tranny and the rattle was worse then before. I felt bad, Pete felt bad, James laughed it off but also felt bad I'm sure.
            It's a mysterious rattle. Another example of its weirdness.
            My original transmission for my red car has 212,xxx miles on it. I was just barely beginning to hear it rattle. Then during my build I damaged the shift rod. I upgraded to a lower mileage transmission with 103,xxx miles. Installed, started, drove, neutral, clutch out, RATTLERATTLERATTLE.
            moral of the stories, nothing is broken. Just deal with it. :-)
            1987 PRO-3 car /1990 325is (2.7i Concours)
            • vonfrost
              • Jan 2009
              • 32
              I know this is an older post; I'm just happy that I found it...This rattle noise is driving me crazy and I was ready to tear my tyranny apart.
              Sitting in neutral=rattle, rattle, rattle engage the clutch and the rattle gone?
                • 34844
                supposedly it's actually the layshaft bearing and not the input shaft bearing. a ltw flywheel makes it worse. Mine has 255k on it and it rattles; it's not unbearable but I've gotten used to it over the last 30k. It would be nice to rebuild mine and make it smooth though..
                • Liam
                  • 753
                  1st motion (input shaft) bearings, Counter gear and countershaft berings. It's very typical.
                  I t's not really a good Idea to try to rebuild them though, The parts that wear: Countershaft, berings syncro rings and hubs cost more than an OE reman trans and to do it correctly you need a bunch of special tools including a jig and something like a 20 ton press.
                  Also a real light flywheel will make a bunh of noise even on a tight transmission.
                  I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                  • vonfrost
                    • Jan 2009
                    • 32
                    This sucks....so, for how long can i drive like this? what kind of damage am i looking at if i keep driving?
                      Pretty much forever if the problem is input shaft rattle while in neutral. The noise is irritating, but not harmful.
                      • vonfrost
                        • Jan 2009
                        • 32
                        Thanks jlevie, this is good to know. Other than the rattle while in neutral the car works really well. Man! these cars have a lot of little bugs.
                        • Liam
                          • 753
                          I probably sounded like doomsday didn't I (didn't mean to scare you).
                          Yes they will go on a very long time like this.
                          • rThor432
                            • Feb 2007
                            • 3907
                            My 250k 260 with a light flywheel doesnt rattle a bit. I must be lucky.
                            • wagonizzle
                              • Sep 2006
                              • 443
                              For those of you not using it, I HIGHLY recommend Redline MTL/MT-90 for the getrag. Major improvement in mine, as far as getrag rattle goes.
                              Originally posted by chileelky
                              amaze about the enthusiasm e30 generate
                                • 34844
                                that's what I'm using. lol. I don't even wanna know what it would sound like with ATF. ugh, shitty cost cutting measures..
