2.5 head on eta block???
  • davide30
    • Sep 2004
    • 7
    me im runnin 8 psi with my eta and they are very fine , but now i going to put an 2.5 head with all the parts , motronic 1.3 all fuel injection systeme. but i know if we run the 2.5 head you suppose to get new pistons but me i run a turbo and lower cmopression its better for turbo engine. but i would like to know which compression it suppose to do with 2.7 stock piston??
    THANK you
    Dave
  • Jonathan M3
    • 1837
    I believe it would drop you down a bit too much, to somewhere around 7:1, but someone may need to verify that.
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • LowR3V'in
      • 4209
      CR will be cool 7.9:1. ;)
        • 34844
        that's going to be a dog until your turbo spools up.. can you say laaaag?
        • LowR3V'in
          • 4209
          I don't know, I've been told by two people that's done this that it feels like a normal 2.5 off boost will alittle more botten end. :?
          • reelizmpro
            • 9552
            I say do it. A ratio of about 8:1 is ideal for running high boost! And with the 2.7 and high flow "i" head it'll be awesome. I would definately do it if you expect to make any serious power.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • bmdubya84
              • 14
              DONT DO IT!!! the stock ETA crank is CAST it can not handle anything higher than 5400 RPMs before exploding into pieces...trust me a friend of mine did it and lost a good block and head...you need a forged or billet crank to handle the rpms...not worth it...trust me...
              no longer using this username, reffer to gotKRAUT
              • LowR3V'in
                • 4209
                Is the 2.5 crank forged ?
                • EverWiser
                  • Aug 2004
                  • 313
                  This is news to me...Maybe someone else can chime in but the reason for the lower RPM's on the eta's (from what I've read/heard) was due to the single valve springs and concerns that the valves wouldn't get out of the way of the pistons at higher RPM's. Also, there are a lot of engines redlined at well over 6000rpm running on cast cranks. Can someone else chime in and clear this up? :shock:
                  • bmdubya84
                    • 14
                    to my knowledge it is yes...i have heard this from several dfferent places now...but i have lso heard of successful conversions from various sites...so i dont know but from experiance it could not handle it..
                      • 34844
                      BZZZT! sorry, the 2.5l crank is also cast, and it easily can handle 6900rpm. you'll be breaking rocker arms long before you break a 2.7l crank! Also, the forged TD 2.7 crank is quite a bit heavier and essentially gives no benefits over the e crank, unless you were planning mad boost, but even then it's not really neccesary (look at TCD's stock 2.5 turbo).
                      • EverWiser
                        • Aug 2004
                        • 313
                        That's what I thought.... :up:
                        • Ryan Stewart
                          I Love Miatas
                          • 8978
                          The only thing I think you might want to consider is bearings/lubrication. Im not an M20 internals expert but I think I recall the B25 having another bearing and journal.
                          Im now E30less.
                          • Jonathan M3
                            • 1837
                            • bmdubya84
                              • 14
                              oddd........hmmm then explain to me why this happened twice in 2 situations...? just curious
