Wheel torque specs when using wheel studs and lug nuts?
  • DrewC
    • Nov 2008
    • 61
    My car came with H&R wheel studs and lug nut conversion, but I'm not sure if the torque is the same given the different setup. Or is it?
    TIA! :D
    1986 325ES LeMons Racer
  • Need4Speed
    • Jul 2008
    • 95
    Same, but basically just not more than 90 ft lbs.
    • GotCone?
      • Jan 2008
      • 589
      Ask supplier of the studs as they are all different.
      some ask you to use anti-seize.
      FYI Vorshlag's studs request this and IIRC torque spec is 70-80 ft. lbs.
      Build : Das Drehmoment Ungeheuer
      • Need4Speed
        • Jul 2008
        • 95
        70-80 is stock specs (79) it is more determined by the rim/nut seat angle and material than the thread.
          I agree, It doesn't matter whether you are using lug bolts or studs. Torque either to 80ft-lb.
          • Adrian_Visser
            • Jun 2006
            • 2823
            i dunno about using anti-seize. I mean if the manufacturer recommends it whatever but having the lug nuts rust on there a bit is a good thing if you ask me. Less chance of them coming loose. Also who the fuck actually torques their lug nuts on anyways get em tight then get em tighter than that. nothing wrong with over torquing them a bit, i mean 80ft. lbs. isn't really that much torque on a bolt/nut that size, just make sure you do it in a star pattern.
            '89 Alpine S52 with goodies
              A bit of anti-seize on the threads of lug bolts or studs is a good thing. That will prevent galling of threads as the lug bolt/nut is run on and off. Properly torqued lugs won't loosen and you don't run the risk of stripping the threads. I always torque lugs as it takes little time and is good insurance against damage to the lugs.
              • Eric
                • 5142
                you're dumb
                • DrewC
                  • Nov 2008
                  • 61
                  Really? That dumb?
                  • Stevie30
                    • Apr 2007
                    • 1534
                    Adrian, In your case torque them to 1/2 turn short of twisting off. LOL
                    1991 325ic and 1991 318is
                      • 34844
                      lol. ask dan gillian what happens when you can't be bothered to use a $25 torque wrench. ;)
                      anti seize FTW. lug nuts are a wear item.. I destroyed my first set of vorshlags in a year (lots and lots of wheel changes). I'm glad I have studs because i would have destroyed the threads in my hubs by now.
                      • Fidhle007
                        I can fly, motherfucker
                        • Oct 2005
                        • 7209
                        You sir, are a fucking idiot. Take a few minutes and learn about the effects of stress on metal then come back and read your post.
                        '89 325is S50 Track Montser
                        '04 X5 Daily/Tow Vehicle
                        http://www.avarestoration.com
                        http://www.myspace.com/brendanfiddle
                        Click here if you want to be my zombie slave...
                        http://www.youtube.com/user/Fidhle007
                        • FLUTE007
                          • 485
                          id say just bouble the spec. 160 lbs. thats good right? the manufacturer prob. dosnt know anything.
                          • Fidhle007
                            • Oct 2005
                            • 7209
                            Nah, why the hell would they research the stress limits of metals used on vital parts of a car? Fuck that man, get a real torque wrench and go to 350 ftlbs.
                            • iignite
                              • 125
                              one reason for warped rotors are uneven torque nuts values and un-patterned tightening sequence
