Clutch Stop ???
  • BlackSpeed66
    • Apr 2008
    • 624
    I went the Home Depot route for mine. Works like a charm.
    If you unscrew the plastic cap in the floor you can take it to Lowe's or Home Depot and figure out the thread size.
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '95 Jaguar XJR-6
    '02 Range Rover 4.6 HSE
    '98 Disco 1
    • blueapplesoda
      • Dec 2005
      • 1904
      I've had problems using clutch stops.
      After a hot day at the track and running the car for 20-30 minutes at a time, the clutch engagement point started to change, going further towards the floor. This resulted in progressively harder shifting, and then some trans grinding. I adjusted the clutch stop which fixed the problem, but the next morning, the engagement moved back to where it was before tracking the car, giving me about an extra inch of travel after disengagement. This was all with
      I ended up just throwing the clutch stop in the toolbox and driving without it. I also race other cars that have the clutch button to start the car (no clutch stops), and I find that it takes less time to re-familiarize with the other car's clutch engagements/pressures without a clutch stop. Having no clutch stop also helps modulate when problems in the clutch system arise, like for instance if your slave/master starts to act up during a race due to low brake fluid level during a turn or something, sometimes stomping on it all the way to the floor and letting it spring back up a few times temporarily fixes the problem. If you had a clutch stop, you wouldn't be able to do that.
      • shiftbmw
        • Oct 2005
        • 2012
        I have a stop in one out of the two and I think I prefer it without...
        "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
          • 34845
          or you could fix your clutch?
          • accident
            • 7303
            I'll buy that clutch stop from you.
            Moral of this story?
            • guibo09
              • Dec 2008
              • 834
              a clutch shouldnt heat up more while laping, unless you are poor at rev-matching and shifting in general. clutch should only take a beating on drag starts, and there isnt much of that during a day at the track.
              also try using quality brake fluid for your clutch. 20 year old dot3 isnt gonna do the job.
              90 E30 325i
              • george graves
                • 20003
                I almost put in the trash....
                Originally posted by Matt-B
                • accident
                  • 7303
                  PM me a price?
                  • Simon S
                    • Oct 2004
                    • 3758
                    A bolt that works is an M10 x 40mm with 1.5 pitch
                    A CAB hex bolt is just the part. (# 31111137888 )
                    #10 in realOEM pic
                    I installed new bolts while replacing cab bushings - so there was one in a used nut/bolt/washer can that I keep. When making visits to bone yards – misc clips, fasteners, and small trim pieces are snagged on sight - so I had some damper caps to choose from. I think the cap I ended up using was one of those little, black, round covers that go on exposed bolts which fasten front seat brackets to floor board. Part# 72111929421 is a comparable cap. #9 in realOEM diagram
                    This pic shows 2 OE stops, 3 cover caps, washer, M10 locking nut, and above mentioned CAB bolt.
                    The bolt would only drive in so deep (was not an open threaded hole to engine bay) so the bolt/washer were matched to OE unit.
                    Installed
                    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                    • daniel
                      • 6703
                      i was disappointed to find that my current car having a transmission swap means it lacks the hole required to screw in a clutch stop.
                      http://instagram.com/dslovn.drives
                      • accident
                        • 7303
                        drill it :D
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Elevator bolt is the answer:
                          McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                          You can get them at most hardware stores. Not exactly sure what thread size you need though.
                            • 34845
                            it's there. you just have to cut a hole in the carpet.
                            • dashboardmonkey
                              FUCK YOUR WAFFLES
                              • Jun 2008
                              • 6158
                              I have the UUC adjustable one, makes for fun flying through the gears
                              -Andy
                              • jayE30_dream
                                • Aug 2009
                                • 8
                                I did the DIY clutch stop and adjusted it to have an extra 1/4+ inch of gap after the clutch disingages but with the recent temps of 10 degress and not gettin above freezing during the day my pedal had to be depressed farther so i had to take the stop out. Is this common with a clutch at cold temps or is it getting close to needing replaced?
                                If you havent seen the future your not driving fast enough...... thats why we have turbos.
