Rediculous clunking coming from the rear end
  • Mitchel
    • Jan 2009
    • 35
    I just actually picked this car up as a daily, knowing about this issue.
    The owner didn't know what it was. It's not coming from the tranny and it's making a very obvious thud sound. Doesn't happen when coasting in neutral and there is a delay in power delivery.
    So I'm guessing that the driveshaft is the only thing holding the diff in the car OR the center driveshaft bracket is broken.
    Any guesses? I'm jacking it up in the AM.
    This is an 85 325e.
    Problem Solved. It had an invisible guibo installed...I can't believe it drove!!!!
    1998 Hellrot M3, perpetually on jackstands
    1985 325e
  • norcalE30
    • Dec 2008
    • 932
    eh, does it happen rapidly when your accelerating? if so its the center bearing. if it only happens once, or when you go over bumps, its prob the diff mount... i think thats more of an e36 problem tho right?
    Originally posted by kronus
    pff, all of you are slow as hell anyway. Eta > all
    • twright
      • 705
      Mine did this when I bought it. The PO thought it was the rear subframe bushings. It turned out to be an exhaust bracket! Go back and shake the exhaust and see if that produces the noise that you are hearing.
      • accident
        • 7303
        +1 for center support. If you replace the CSB do the guibo at the same time, it's probably begun to crack from the angry shaking.
        Moral of this story?
        • norcalE30
          • Dec 2008
          • 932
          mine was shredded when i bought it, make sure you check it
          • EN318isPDX
            • Oct 2007
            • 4373
            Most common issue on all E30s, CSB
            • 2002maniac
              • 4260
              usually caused by a bad rear u-joint.
              • Bouncin n my bimma
                • Jan 2009
                • 44
                Or just extreme wear and tear.... These are 20+ year old cars... But damn are they fly! Bmw should do a reissue/update.
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  holy shit how the hell is there no guibo in there? could it seriously just break apart and fall out?
                  '89 Alpine S52 with goodies
                  • ethree
                    • Aug 2007
                    • 1213
                    If you drive for thousands of miles with it flopping around down there.
                    I'd go ahead and replace the driveshaft, csb and guibo along with the dif mount. That shaft must be wasted.
                    • Mitchel
                      • Jan 2009
                      • 35
                      The driveshaft isn't just going to fall out, but the flange bolts will bind on eachother and transfer power to the wheels.
                      This is by far the WORST guibo problem I have EVER seen. And I used to replace 2 per year on my M3 =P
                      1985 325e
                      • norcalE30
                        • Dec 2008
                        • 932
                        holy hell....
                        • Knockenwelle
                          • Jul 2008
                          • 395
                          I hope the trans pilot is OK, though the needle bearing in the shaft is likely wasted.
                          Mike
                          '91 325i track car. Mostly...
                          • Mitchel
                            • Jan 2009
                            • 35
                            I'll find out tonight what kind of fallout this guibo or lack there of has caused.
                            1985 325e
                            • bimmerboy12
                              • Jun 2004
                              • 1057
                              haha mine was the exact same way when i bought my car. towed it home at about 10 mph... BAM-BAM-BAM-BAM
                              1988 325iC Project - FINISHED!
                              Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
