M30 progress - UPDATE 3
  • Digitalwave
    is a poseur
    • 6282
    #31
    Originally posted by M-technik-3
    Originally posted by JPbmw
    m30b35= 211hp :twisted:
    m50= 170
    thats one of the reasons why im doing the m30 swap
    M50=193
    M30 EU spec is 211
    M30 US spec is 184
    Ignorance is bliss.
    RISING EDGE
    • M-technik-3
      • 18946
      #32
      m50= 170
      M50=193
      M30 EU spec is 211
      M30 US spec is 184
      Ignorance is bliss.
      True but there are many EU spec M30 as I do know there is another EU spec that makes 218 hp.
      • Digitalwave
        is a poseur
        • 6282
        #33
        m50= 170
        M50=193
        M30 EU spec is 211
        M30 US spec is 184
        Ignorance is bliss.
        Yeah but how many of those motors are in the US? You set him straight I think.
        RISING EDGE
        • kylebes1
          • May 2004
          • 2804
          #34
          if you want naturally aspirated hp you should go with the m88 or even the s38, both are DOHC.
          I think like what's his name, I enjoy a challenge, but I owuld have to have some more morny to dive into a m88 or s38 swap,
          • george graves
            • 19993
            #35
            M50 = Direct bolt in
            M30 = A bitch and a half to install (I think George and Ryan would agree).
            Ryan and I have ran into a few snags. The curent one being transmittion. We got a parts car to get the 5-speed out of, but turned out that the tranny was way shorter then the getrag 265 we were trying to replace. We also had prolbems with electrical, the wireing harness came from a auto, and we could not trick it into thinking it was in "park/neutral" The motor was also shipped/arrived with a bad crak sensor(not positive when it wend bad)
            If it had been a m50 I was swaping in we could have had it done in a weekend or so.
            M50=193
            M30 EU spec is 211
            M30 US spec is 184
            My understanding is that the only difference between the motors is that the US version had a very restrictive cat. That was back in the day when cats sucked. So I think a high flow cat sould solve that prolbem and let the m30 flow as much as the eu version.
            Originally posted by Matt-B
            • M-technik-3
              • 18946
              #36
              Cam is differant from what I have heard due to better fuel.
              • kylebes1
                • May 2004
                • 2804
                #37
                I could have done my m50 swap in a week, almost did but my LWF was two weeks late and my m10 was about to seize up.
                I guess you guys are going to rip off the auto harness and redo it or what have you decided?
                grab two Corvette (early c5) TB and make a custom inake manifold, you coudl pick up some pwr there if you plan to boost it, which there is no poin in a m30 unless you are.
                • rs4pro3
                  • 5808
                  #38
                  They got the wiring worked out, They ended up ussing a 325i engine harness.
                  That sucks about the driveshaft, so what are you doing? New shaft and shortened again?
                  85 325e 2.7 ITB'd stroker
                  • george graves
                    • 19993
                    #39
                    The drive shaft is fine - it's not getting cut again I can tell you that. It's just that the getrag 265 tranny is a lot longer than then 260/5 we tried to replace it with - so now we are getting another 265.
                    Oh - what this "no point in do a m30 unless you do forced induction" ???
                    • kylebes1
                      • May 2004
                      • 2804
                      #40
                      IMO that is right
                      Well I guess you could shave the head like my buddy did, but I have not gottena ride in it yet, he could be full of it far all i know.
                      • Funkmasta
                        • May 2004
                        • 7185
                        #41
                        George, keep up the good work!!!
                        BTW, if you have any friends that want to do the same swap, I have an 88 M6 motor now... I want to see your car when you drive through Portland over Xmas break
                        Joe Funk -- Portland Oregon
                        That Guy.
                        03 X5. 3 liter obviously.
                        • JPbmw
                          • 466
                          #42
                          m50= 170
                          M50=193
                          M30 EU spec is 211
                          M30 US spec is 184
                          Ignorance is bliss.
                          actually the US m30b35 has 208hp
                          '86 325
                          • Funkmasta
                            • May 2004
                            • 7185
                            #43
                            up to 87 was 184 hp, 88+ was 208 :P
                            That Guy.
                            • PanamaE30
                              • Oct 2004
                              • 768
                              #44
                              Just out of curiosity.. i saw on a webpage that in europe they had a 333i.. I'm assuming that would be an M30. Couldn't you just use parts off one of those puppies and make the whole thing plug and play?
                              1988 325iC - "Betty" - Daily Driver/Project Car.
                              1993 318i - "The Golden Dream" - Dad's Car.
                              1995 318ti - "Hellrot" - R.I.P.
                              • E30/M30
                                • 224
                                #45
                                Hi George,i've finaly got my 335i Touring done today ! 8)
                                There's a few niggle's to iron out like my brake's are sticking and my clutch need's bleeding again but nothing major.
                                It's to dark for picture's tonite so i've done a small sound clip so you can hear what it sound's like with the cone filter and M3 Scorpion exhaust.
                                right click and save as
                                Cheer's
                                Andy
