How much would a manual conversion cost?
  • Zingledot
    • Sep 2004
    • 1
    I see a bunch of threads in here about details of it....but since I'm not at that point yet, how much would it cost for a shop to do it all, do you think?
  • Jordan
    • 12916
    Can be done for $600 or less.
    https://mtechniqueabs.com/
    • rwh11385
      lance_entities
      • 18403
      Re: How much would a manual conversion cost?
      the cost of buying a manual E30......
      ask someone how many hours it took to do the conversion, multiply by $70+ per hour then add surcharges and over-priced parts for stuff you could have new.
      Just a guessimation: say it's only 20 hours of labor, and they charge you $500 for the transmission (probably way more they'd charge you) and just $200 in shop fees, misc parts, etc.
      That is $2100!
      • M-technik-3
        • 18946
        Shops that do them on common basis are 12 hours of labor.
        • spencers
          • Jan 2004
          • 1150
          Yep.
          • rwh11385
            lance_entities
            • 18403
            Okay then 12 hr x 60-85 -> $$$
            TMS is $85 IIRC, x 12 = 1020, + charges & parts
            • Digitalwave
              is a poseur
              • 6299
              Maybe if you used all used parts. I spent about $500-600 alone on replacing the big wear parts so it was all fresh. Then add the tranny, driveshaft, pedals, etc. on top of that.
              RISING EDGE
              • DEV0 E30
                • Oct 2004
                • 8904
                How much did it cost you total? Ballpark it if you can, my 84 eta is auto and I'm really deciding my options weather or not to change it or buy a later 80's e30 with a 5spd already in it.
                • Digitalwave
                  is a poseur
                  • 6299
                  I think around 1,200-1,300 but I did some nice upgrades to go along with it.
                  RISING EDGE
                  • DEV0 E30
                    • Oct 2004
                    • 8904
                    Would you reccomend it, and make the eta motor worth it? Or get an i model with a 5spd?
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Originally posted by Gruelius
                      • Digitalwave
                        is a poseur
                        • 6299
                        Personally, I would buy a 325i 5 speed instead of investing the time on an eta. It really depends on how attached you are to your car though. I could have just sold my car for another one that was 5 speed already but it was worth it to me to keep it. The way I saw it too, was that at my car's age it would be needing a new clutch anyways, and I would be spending most of this money no matter what...
                        RISING EDGE
                        • boom-monkey
                          • 1104
                          I just met a kid up at college that did the whole swap for 250 with new parts, just gotta have connections.
                          • bimmer8604
                            • 3017
                            im in the position where i have all the parts i need, plus new clutch and my LTW. i am just debating weather or not to try the swap myself, or take it to the shop. i dont have a lot of time on my hands, and I need a car for school/work.
                            Kyle
                            1988 M3, 97 840, 99 XJ
                            DILLIGAF
                            • James Crivellone
                              Head Janitor
                              • 6305
                              do you have motor swap plans? if so, yeah its worth it, if not then buy an I
                              I's are not that fast either, which is why I don't consider them better at all, I have fucklots of fun in my eta, and swapping in my manual completely woke the car up.
                              the ETA is a hella fun engine once you open the exhaust/intake and chip it
                              325i intake manifold and throttle body help alot as well....
                              depends on your plan, only I car I personally would get is an 87, cause I like the early models better then the newer late models
