Removing old engine... putting in another m20
  • Fuddy
    • 123
    the engine I'm going to install is from an automatic.... my brother says there has to be something changed or pulled out from the automatic before it can be mated to the maual tranny I have.
    Is this true? Does the flywheel have to be changed?
    TIA
  • Bill 84 318i
    • 1600
    Yeah - you have to swap flywheels (and clutch assembly and stuff) and put a pilot bearing assembly in there.
    Are you doing it at a shop or what?
    • Fuddy
      • 123
      yeah, my nephew's godfather has a shop... I took apart the engine myself to get it ready for pulling...
      we're pulling it today...
      just waiting for my new clutch, belts and other shit to come in... already changed the timing belt on the new engine
      so I need a new pilot bearing huh?
      • Bill 84 318i
        • 1600
        Well, the crankshaft on the automatic engine isn't gonna have a pilot bearing in the end of it.
        I guess you could use your old one if it's in decent shape, but it's real cheap new.
        • Digitalwave
          is a poseur
          • 6299
          Just unbolt the auto tranny, torque converter, flywheel, etc. Disconnect all the tranny cooling lines. Disconnect the tranny fluid dipstick from the engine block. Then you should be set.
          Now would be a good time to replace your clutch, replace all the tranny seals (and the rear main engine seal, maybe oil pan gasket), all the good stuff.
          RISING EDGE
          • e30evolution
            West Werks
            • 1888
            autos dont have flywheels... it is called a flex plate... so you arent changing the flywheel.... you are replacing the flex plate with a flywheel
            but yes that is all you have to do
            http://www.westwerksauto.com
            • 318driver
              • 1714
              why are you swapping engines?
              90 325is
              IE stage 3s and refeshed m20....
              • Pat W
                • May 2004
                • 321
                whats wrong with the old engine.....maybe i could get some parts for my 2.7i buildup for my E.... :D
                JDM no more
                • Fuddy
                  • 123
                  either a busted piston, or messed up head... don't know yet...
                  and my car is stick, the engine I'm getting is from an auto...
                  I paid 800 for an 80k engine
                  doing the clutch while I got the engine out
                  • Fuddy
                    • 123
                    the head may still be good, won't know until I take it apart
